Got a game tonight, and I can’t settle on how to equip my D.Smith. The plan is to drop him back by the warmachines while also being a scroll caddy. To this end, what do you normally spend the remaining magic item alotment on?
I find less is more with them they core the earth already use your look out sir to keep him alive and put the points in to other areas with chaos dwarfs you never have enough points to go round for everything. he is going to be carrying the chalice or the scroll I assume so I don’t think you need to invest any more points in to the little guy. blog has a good point however if your level 4 is tucked up inside a unit of infernal guard he wont need the charmed shield so if you have the points stick it on your level1
Why do you even give him a charmed shield? Your BSB or Lvl4 can benefit from that so much more. Its not like you don’t get a 2+ look out sire near warmachines already. If your worried about cannons its going to snipe both you and the machine anyway, if he lives and the machine dies that arse barkwards. You want machine around till bitter end, he can go once the shelling is over or scroll is used up. IE hes not worth saving with too much gear because of how low his points are compared to the others. If you want to use a charmed shield give it to a khan on a wolf and don’t give him heavy armour. He might survive the firing phase long enough to make contact.
