Anvil of doom,master rune of balance,2 runes of spellbreaking,master rune of gromril,rune of preservation 455
Very costly, but I want to try it out. Modelled as some kind "altar of hashut" or something. Bring some decent magic defense in the form of 8 dd and 2 dscrolls
Master Rune of Gromril is wasted here, a simple Rune of Stone and a shield gives him a 2+ which is good enough. If he's in combat, you've probably done something wrong. Master rune of Balance is expensive, and not that great imo. Master Rune of Spellbinding is better, but similarly overkill unless you are playing vs VCs.
Not sure about the other heroes. Suggestions?
Get a BSB. Master Rune of Gromril, Rune of Striking and 2 Runes of Cleaving turn him into an absolute beast. Other than him, I would suggest a Master Engineer, as you seem to like artillery :)
25 dwarf warriors shields full command 250 points
Good, although I would upgrade one unit to Longbeards. Re-rolling panic is pure gold.
10 quarrellers shields 120 points
I would swap one unit for Thunderers.
8 bolt throwers or 4 cannons both are 360 points
Dude, don't do it. It will lose you friends and isn't even that good. Get some Hammerers (BSB goes here) and some Slayers (10-15). The extra movement from the anvil makes these guys very useful.
Then have 1-2 runed up machines that you can protect, rather than 8 that you can't. I like 2 Bolt Throwers (both strength 7, one flaming) although the cannon is good if you go for the Master Engineer.
2x organ guns 240 points as different death rockets or earthshakers
Harsh but a lot of fun. Never underestimate the Gyrocopter though, its march-blocking can be useful when used in conjunction with the anvil (to slow down multiple targets), plus nothing clears out Zombies like a template weapon.
My Gt list (qualified for the finals, finished 50th or thereabouts 2 ago) was something like this:
Runelord on Anvil
+3 Runes of Spellbreaking +Rune of Stone +great weapon, shield
BSB
+Rune of Striking +2 Runes of Cleaving +Master Rune of Gromril
Thane
+Master Rune of Challenge +Rune of Stone +great weapon, shield
(Joins the Hammerers to pull in large flyers and stop them getting the artillery)
20 Warriors
+Shields, full command
10 Thunderers
10 Quarrellers
20 Hammerers (Thane goes here)
+Full Command +Rune of Courage
10 Slayers
5 Miners
Cannon
+Rune of Forging +Rune of Burning
Organ Gun
Gyrocopter
For 2250 I would simply add some Longbeards and some more Miners.
My army is in the gallery section if you want some ideas: http://www.chaos-dwarfs.com/army6.php
