Saxon
22 April 2009 02:43
1
Scion :
This my idea for a mount for a Chaos Lord. For the model imagine a petinent engine with a Chaos Dwarf and some extra guns. I was thinking that maybe smaller versions could also have slaves wired in them. Well he doesn’t actually mount it I guess, merely becomes it…
I was hoping maybe you could play-test it, see what it’s like.M WS BS S T W I A Ld
5 6 5 5 4 6 1 5 10 Weapons & Armour
Scything Blades
Armour Plating (4+ AS) Upgrades: May be given shoulder blasters at +25pts
May swap one scything blade for repeating shotgun +20pts
May purchase extra armour for +9pts Special Rules:
Immune to Psychology
Terror
Drugged: The engine will never break from combat. Weapons: Scything Talons: -2 to AS
Extra Armour: +1 AS
Shoulder Blasters: Range:18", Strength 4, x2 multiple shots
Repeating Shotgun: Flame Template, Artillery dice" is added to the distance, S3, x3 multiple shots.
Itzi-Bitzi :
Chaos Dwarf Engine MKIII Point: 500 Engine: M WS BS S T W I A LD
4 5 6 4 5 6 1 5 10
Special Rules: Deoman Bound,
Untold Age, Terror Daemon Bound
�?o Each engine is powered by a Greater
Daemon of Chaos, it rage powering the
Grand machine, however the soul of
the Daemon is always trying to take
control of the machine, so the the engine
seer mounting it must fight to control it…�?�
Each Turn Roll on the Daemon Bound Table:
Roll 1D6
1- The engine is cannot move that turn of
commit any other action.
2-3 The Engine gains the Frenzy Rule
4-5 The engine now has the frenzy & Hatred
rules.
6-All attacks have the killing Blow!
Untold Age
�?o Each engine is created and custom built for a
dwarf lord who orders the seers to create weapons
never seen before, due to there age ad different
manufacturing improvements each engine has
unique engine & weapons �?�
The Engine may have two arm weapons in addition
to two shoulder. For each weapon choose a normal
weapon from the rule book selection, and roll on
the following tables. Note: If Close combat weapon
get 3-4 on stage 2 or 5-6, 3-4 on stage three may
re-roll dice. Do at star of game. Chaos Dwarf Weapons:
Chain Sword
�?o The engine is equipped with a a massive chain saw,
used like a great sword, its buzzing chain cleaving
through all its foes�?�.
All Weapons Only. No armour save, +1 strength
Causes D3 wounds.
Gatling Gun
�?o This incredible contraption feed bullets into the
main chamber, firing many a shot, but alas, it takes
along time to reload�?�.
Shoulder & Arm. 5X Multiple shot at Strength 4
Range: 36�?�
Shotgun
�?oThis is a Massive blunderbuss, big and heavy with
loads of nails, kitchen sinks and lead piled into one
barrel�?�
Shoulder & Arm. May be fired while in close combat,
D6 hits D6 strength D3 wounds
Cannon
�?oThe Engine is equipped with a artillery piece
capable of blowing away Anything in its path�?�.
Shoulder Only. Fire like a cannon form the
warhamer rule book.
Range: 34�?�
Strength:10
D3 wounds
Forging Table
Warp Up
1-: Nothing
2-: +1 to hit
3-: May re-roll-roll hit
4-: Flaming Attacks
5:- Poisoned Attacks
6-: Poisoned on 5+ Forging Table
Final Stage
1-: Nothing
2-: Killing Blow
3-: re-roll to wound
4-:Killing Blow
5-: Poisoned on 4+
6-: Killing Blow on 5+
