I think that looks really cool. Maybe some feet are needed on the semi-circles upon which it stands, but beyond that, very cool concept. It;s like a dog straining at its lead. Kudos.
Very kool idea, looks imo great, it has “this feel”.
If you 'd like to have ur sculpts better, in case of mask, after you make a hole for an eye, the sides of the hole are slightly pushed in. Put ur sculpting tool inside, (but only partialy) and very gently slide the sides up.
Eruption guns are light war machines that come in a variety of forms from compact swivel cannons to shoulder-mounted �?obazukas�?� or even diminutive-sized mortars. Crewed by a team of Chaos Dwarf weapon smiths, Eruption gun teams act as axillaries, supporting large contingents of Chaos Dwarf warriors with hails of deadly missiles and rockets. When the daemonic presence within is awoken, flickering barded tongues, and gullets of lurching fangs run wild with the yearning of devouring the enemy�?Ts flesh and blood. Special Rules Slave Lords; Unyielding; Daemon Engine Eruption Gun Eruption Guns must be deployed at the same time and within 3�?� of the Chaos Dwarf unit they have been bought with. Afterwards, the Eruption Gun counts as a completely separate unit for the rest of the game. Range Hits/Shots Strength Armour Save 24�?� Artillery Dice 4 -2 Firing an Eruption Gun Eruption Guns may be fired in the shooting phase and have a range of 24�?�. Choose a target unit in line of sight, then roll the artillery dice. If a misfire is rolled, roll on the Daemon Engine misfire chart. If a number is rolled, this number is the number of shots the Eruption Gun has fired. Roll �?~To Hit�?T as normal for each shot fired using the BS of the Gun, applying all normal �?~To Hit�?T modifiers, though the penalty for multiple shots does not apply. All hits are resolved with the above profile. Base Size The Eruption Gun is a single model on a 40mm base. Accompanying Chaos Dwarf �?ocrew�?�, if you model any, should be modelled on the same base with the Eruption Gun. ERUPTION GUN m ws bs s t w i a ld Eruption Gun 3 4 3 3 5 2 1 2 9
