Bringing three Khans on wolfs is funny - especially with various magic items. Your opponent is gonna loose warmachines or waste shooting taking them out.
I think you should try to get another standard on the second unit of archers.
Why? Standards are pretty no use in ETC comp... (with some exceptions)
He can get 2 more hobgoblins with the standard points... And not give 25 more pts when losing it, and he may lose it...:)
Strange list, playing 2 prophets is uncommun. Need a try to see if you have enough dices to cast spells.
Just an opinion, with only 2 warmachines, I'll go without the daemonsmith and dispel scroll on one prophet...
Why? Standards are pretty no use in ETC comp... (with some exceptions) He can get 2 more hobgoblins with the standard points... And not give 25 more pts when losing it, and he may lose it...:)
Strange list, playing 2 prophets is uncommun. Need a try to see if you have enough dices to cast spells. Just an opinion, with only 2 warmachines, I'll go without the daemonsmith and dispel scroll on one prophet...
zhatan87
well i'll try out this one and if it doesnt work because of spell dices will try instead of lvl 3 with tauruk with dawnstone, dragonhelm, blackshard armor. 1+ rrorllable armor, W4, T5,A4 S7 2+ ward against flaming.
I’d be tempted to make your lvl3 the general. He’s less likely to be big casting (even though Death is capped at four dice) and the number of times I’ve misfired a Purple Sun killing my lvl 4 is not even funny.
There are limited dice in ETC, but I can see you having 12 as you’re taking Death, also it gives you 7 spells (+ DS), the same as a loremaster, and no one says that’s rubbish, it’s about having utility.
Other than that, others have covered it. I’d be tempted to get a BSB, maybe even the Banner of Slavery to stop your hobgobs being terror checked off (esp your Khans if you hold them back)
