As you may read in the thread, this issue is a little light due to being let down by contributors. However with Willmark’s guidance (in the form of a whip knowing him ) Issue 4 is going to be a belter, so please don’t let this issue put you off.
In all I think it way not bad Baumann did a darn good job with not being a designer. As noted I will be stepping into produce the graphic work and layout for Issue #4. If I imagine right next one should be out in April.
