[Archive] great weapons(1)
astragoth:
i am going to make some warriors with great weapons, will these be good great axes: ?
http://www.games-workshop.com/gws/catalog/productDetail.jsp?catId=cat1440009&prodId=prod1570034
and what else can i use(for great weapons)?
:hat off
Guardian_A:
I’ve seen Chaos dwarfs done a couple of different ways. One is with the Chaos Warrior bitz you are looking at. The other way is with regular Dwarf great weapons, slightly modified.
Borador:
Or you could use the Chaos Marauder flail ( which no one except for me and maybe some others seem to use? )
Those axes will probably do the trick, but I am not sure about their lenght. Maybe they are a wee bit to long, but that shouldn’t be a problem I guess. Good luck with it :wink:
astragoth:
Those axes will probably do the trick, but I am not sure about their lenght. Maybe they are a wee bit to long, but that shouldn't be a problem I guess. Good luck with it ;)
Borador
i will only use the axe heads and stick them to dwarf miners, so the lenght shouldnt be a plroblem. thank you guys!
