[Archive] gw static grass ( help)
I just can 't get this stuff to look good … no matter how i try . it looks like big piles of glob:mad:mad
any tips ?? free cookies !!!
Grimbold Blackhammer:
Are you talking about the loose ‘grass’ you dip your base into or are you trying to make little stands of bushes sort of like tall grass growing out of the dirt?
yes, that the stuff
Geist:
Kera its all about layers. First put down whatever layer you want to be your “ground effect”, so just a lil bit of basing material or just some glue to dry up. Then once that is dry lightly brush a few drops of watered down wood glue onto the base (aka PVA glue). Then sprinkle grass effect onto the base, as it drys gentle turn the base upside down and knock a the loose bits off. As it drys gravity should help the grass stand right up. The first few times will come out messy, as you get more familer with the process it will look better.
Bolg:
Also, dont buy the GW stuff, there are many equally good or better options for less money out there.
Singleton Mosby:
Use tufts from armypainter joefix or whomever. The effect is way better!
Thorne:
Also static electricity can help it ‘stand’ up better. Best way to get this is to get a plastic or rubber brush nd rub it on something made of artificial fibres then hold it above where you want the grass to stand. The rayon fibres will ‘reach’ for the static source and you now have upright static grass.
I’ve always sprinkled it on and knock / tapped the excess off. But I never thought of inverting them to let gravity help. So thanks for that tip Mr Geist
G.2:
I just can 't get this stuff to look good ..
Kera foehunter
If you like how mine looks, then I can tell you how i do it.
1. Put some PVA glue onto the base. I use a toothpick and spread it around into all the little crevices, like between feet and around cloaks, etc.
Note: If I want an ALL grass effect, I don't do anything else to the base, other than apply the PVA glue. If I want patches of static grass (like in the second photo), I base my model using sand and small rocks, etc, and then paint it, drybrush it, let it dry and THEN I do the static grass.
2. WHen I apply the PVA glue, I put it aside for about 10-12 minutes so that it has started drying a bit, otherwise I find the PVA glue too watery and can make the static grass too saturated, which looks awful, when dry.
3. I Really heap on the grass, so it forms a big mound.
4. I give it light press (push down) with my fingers, or paint brush handle.
5. Again I wait about 3-5 minutes, and then gently tap off all the excess grass into a small tray (or piece of clean paper).
6. I then put the mini aside for a few hours to allow the glue to dry.
7. Once Dry I tap it again, and maybe use an old brush (about size 5 or 6) and LIGHTLY brush away any loose grass fibres.
7. Admire
Here is link to someone else's technique, which is almost the same way I do it (Pictures too).
http://fromthewarp.blogspot.com.au/2010/03/applying-static-grass.html
Note: the brand of static grass I use is the one from Woodland Scenics:
Geist:
Woodland scenics great basing material. No prob for the advice the gravity method works well.
at g.2 that is exactly how I glue it on. I also paint the base with graveyard earth first, it makes great dry looking dirt.
G.2
Woodland scenics here too. Railway model shops seem to exist where GW shops come and go.
I use PVA and sand and once its dry and the model definitely finished, I use an "Artists concentrated ink" burnt sienna liberally over the sand, in the case of my goblins as seen below. Later I spot ares and sprinkle the grass on. The only thing different is I have been using scatter not grass flock
http://www.chaos-dwarfs.com/forum/showthread.php?tid=13282
Thank you everyone for your help…
