I’m going to be making a scale model of a goblin soon to go with the dwarf slayer I’m making. The slayer is 47mm (just happens to be the exact same size as a GW ogre, what I originally intended it for :)), so how tall should I make the goblin? I might make it into a night goblin, but so I don’t cloud the scale issue I’d like it just for a regular goblin.
The original plan was to make an anatomical study of an ogre (potentially for casting), but it came out really well and I figured I might as well use it for golden daemon.
Has anyone ever tried sculpting with a shrinkable clay? I don’t know much about it but you make it then bake it and it shrinks to 1/3 size. Would that work for sculpting? Could you get more detail?
I considered that, but then its whether to go with the smaller night goblins or the regular goblins? They changed the scale.
Grimstonefire
Are you making a Night Goblin or common goblin?
Pick the one you are going to sculpt! :~
I'd say the NG's are smaller on purpose actually. Living in caves = stunted growth, no? Just look at Dwarfs! :hat off
Either way going with the most recent seems to be most correct, ie NGs, the 6th ed Goblins are freakishly large compared to current and earlier editions aren't they.
I’d say the nightgoblin’s hat would come up to same level as the slayer’s mohawk… meaning that a nightgoblin would be a tad bit shorter than the dwarf… say the top of teh goblins head would be about teh level of the dwarf’s nose…
