I’ve been playing warhammer for about 6 months now, and I’ve built up a decent size Dwarf army in that time (2500pts).��With that done, I’m debating my next army, and Chaos dwarves are on the list.
That being said, I’m very disheartened by having to convert everything.��So I am setting up a list that will reduce the amount of conversions so I can get started on 1000pt games.��Then I can at least play some small games while I’m working on the big conversion projects.��I would love opinions on this strategy.
1000 points
Heroes
Chaos Dwarf Hero 66
Heavy Armour, Shield
Sorcerer (Level 2) 100
Core
15 Warrior 165
Champion, Musician, Standard Bearer
10 Warrior with Blunderbuss 150
Special
20 Black Orcs 298
Black Orc Boss, Musician, Standard Standard
Rare
4 Leadbelchers 220
Total 999
All that needs to be converted with this list is 2 heroes, and 25 warriors (15 normal, 10 w/blunderbuss).
After that is done I would start on Bull centaurs to replace the Lead Belchers, and then build up on more warriors.
I know what you mean, I don’t mind converting CD but converting greenskins,well I’d rather not.
I do like using DoW but I would leave the Ogres for the 2000+ mark with these points I would bulk up the CD units and add in some bolt throwers, maybe just use the spear chukkas (no converting required :cheers)
conversions are one of the big draws to this army.��
Malificant
I agree, converting is the bestthing about this army! You have a blank canvass and you can make your army look however you want it to look!
I think if you're worried about converting then you're probably heading up the right road. I would consider getting classic models off ebay for units you will be converting instead of units that you probably wont have a place for when your done, if nothing else it gets you used to using the unit (ie, classic BCs or Earthsaker instead of ogres!) and you may want to invest in a cheap meat shield. You can use normal gobbos for hobgoblins and just paint them with human skin tone!
Unfair but its one of the few worthwhile Rare choices for the army. Bull Centaurs are nice but they’re only really good, then half of your points vanish with one unit. I’d say no more than two Earthshakers at any point.
