[Archive] Irondrake alternatives
gerryb:
I need some Irondrakes for my Mantic Dwarf army ( started off as Mantic AD Dwarfs but sold the metal bits )
The Mantic AD decimators are a bitch to put together, half of them are ok but the double arms are almost impossible to fit.
Perhaps you should ask for alternatives over at Bugmanns Brewery.
Being a Chaos Dwarf general my suggestion to you is: old 4th edition blunderbuss chaos dwarfs.
torn:
gerryb
Just a quick question, are you playing low or whfb, and if it is low are you using them as good or evil dwarfs?
gerryb:
It’s for WFB and it’s for normal Dwarfs :slight_smile:
Heavygear:
It's for WFB and it's for normal Dwarfs :-)
gerryb
Have you considered bits ordering the drake guns and installing them on the the mantic dwarves? You will need to trim the left shield arm from the body, then I would just drill out a shallow socket to mount the Irondrake arms into. It should be fairly simple to do.
