In the indy rules the kollossus is a ridden monster and the crew can fight as normal in HtH … can opponents attack the crew separate from the kollossus itself.
also if a character on top is in a challenge, can the opponent attack the annihilators? or are they also considered part of the mount?
IS there any restriction on size minimum wize on a kolosus?
The name sugests bg, i'm just wondering how small people have gone?
nitroglysarine
I was also wondering this, I see many people have been using 50mm bases, but the indy book does not specify a base size for the kollossus ... I was going to use the siege tower as a base model to work off .... any thoughts?
I would say it depends on your opponents? Casual gamers likely wouldn’t mind, but I can see hardcore guys questioning it. Mine is on a 100x100mm, and hasn’t caused any issues. It’s usually beneficial to your opponent to have it on a larger base, as it becomes harder to move, easier to target with cannon and stone throwers, etc…
