Nicodemus:
So Bull Bentaur base size has been talked about off and on since the models were first mentioned to be in the Tamurkhan book.
In the Legion of Azgorh army Bull Centaurs are classed as Monstrous Beasts (MB in their profile). I spoke with Simon at Forgeworld/Warhammer Forge a few days ago (also mentioned in the thread Centaurs are your friends!) and was told that 40x40mm base was the intended base size for Bull Centaurs. I took his response with a grain of salt, however, as he had to think for a while and check their classification of “Monstrous Beast” before pondering more. BCs are 3 Wound models now and with the Monstrous Beast classification the larger than 25x50mm base size fits with the current treatment of such things in the rules and current models, however, there’s still been talk about 50x50mm bases for these guys. I’m sure some of you have already decided for yourselves what base size to use, but if you’re on the fence (like me) here’s the results of my search through the current WHFB armies for precedent on the base size. Of course you can use any base size you like for your precious dolls, but other gamers might get narky if you want to go out in public with them and try to play with others :P :hat off
In the end, it seems most things in the Monstrous Beast category can be on either 40x40 or 50x50 bases and GW hasn’t been totally consistent themselves with a lot of their models that are classified as Monstrous Beasts. In some cases models that used to be sold with 40x40 bases are now sold with 50x50 (Great Eagle). Essentially, because they’re ‘monsters’ (of a sort) I think it’s somewhat open to your own choice whether you base them on 40x40 or 50x50 mm bases.
Here’s the sumamry of my search through the WHFB line:
Monstrous Beasts from around the Warhammer Realm
Beastmen
Chaos Spawn (3 Wounds) 40x40
Razorgor (3 Wounds) 50x50
Bretonnia
Royal Pegasus (3 Wounds) 50x50 (used to be sold with 25x50)
Unicorn (mount for Fey Enchantress) (-) 50x50 (used to be sold with 25x50)
Daemons of Chaos
Beast of Nurgle (4 Wounds) 40x40
Fiend of Slaanesh (3 Wounds) 40x40
Juggernaut (1 Wound) 50x50
Dark Elves
Dark Pegasus (3 Wounds) 40x40
Sulephet/Morathi Sulephet is a Dark Pegasus, see above.
Empire
Imperial Pegasus (3 Wounds) 40x40
High Elves
Great Eagle (3 Wounds) 50x50 (used to be sold with 40x40)
Lizardmen
Terradon (1 Wound) 40x40
Ogre Kingdom
Sabretusks (2 Wounds) 25x50 (unique apart from perhaps Bull Centaurs)
update: Ogre Kingdoms in 8th edition has Sabretusks listed as War Beast, while in Storm of Magic they are Monstrous Beasts.
Orcs & Goblins
Gigantic Spider (3 Wounds) 40x40 or 50x50
Great Cave Squig (3 Wounds) 40x40
Skarsnik & Gobbla (6 Wounds) 40x60 (unique)
Skaven
Bonebreaker (4 Wounds) 40x40
Tomb Kings
Tomb scorpion (4 Wounds) 50x50 (old GW base size chart incorrectly lists it as 40x40)
Warriors of Chaos
Daemonic Mount (1 Wound) 50x50
Dragon Ogre (4 Wounds) 40x40 (Shaggoth is a Monsters and therefore 50x50)
Scylla Anfingrimm (4 Wounds) 40x40
Wood Elves
Great Stag (3 Wounds) 50x50 (seems to be the consensus anyway)
Unicorn (3 Wounds) 50x50
Storm of Magic
Pegasi (3 Wounds) 40x40 (see GW website->Warhammer Bitz->Mounts)
Royal Unicorns (3 Wounds) 50x50 (see Bretonnia)
Great Stag (3 Wounds) 50x50 (see Wood Elves)
Gigantic Spider (3 Wounds) 40x40 or 50x50 (see O&G)
Dragon Ogre (4 Wounds) 40x40 (see WoC)
Razorgor (3 Wounds) 50x50 (see Beastmen)
Chaos Spawn (3 Wounds) 40x40 (see Beastmen/WoC)
Rhinox (3 Wounds) 40x40
Sabretusks (2 Wounds) 25x50 (see Ogre Kingdoms)
Plague Toads (2 Wounds) 40x40 (see Forge World/Warhammer Forge)
update: Sabretusks are listed as Monstrous Beasts, whlie in Ogre Kingdoms in 8th edition Sabretusks are listed as War Beasts.
Chaos Dwarfs (Ravening Hordes era and earlier, etc)
Bull Centaurs (1 Wound) 25x50
Forge Word/Warhammer Forge
Bull Centaurs (3 Wounds) ? keep reading
Nightmaw (with Sayl) 40x40
So ignoring oddities like the 25x50 Sabretusks and Skarsnik’s 40x60 base, I’m in agreement with what seems like the general consensus around that “Monstrous Beasts” can be mounted on a 40x40 or 50x50 base and there’s lots of evidence to back up that choice. Even the Gigantic Spider seems to be on the fence. Of course there’s always the caveat and general rules that you put your GW model on the base that comes with it for gaming reasons… although we have no current Bull Centaurs so the point is moot.
The real choice between base sizes comes down to two things in my opinion: 1) game play considerations and 2) aesthetics. … and I think aesthetics trumps any game play considerations are they are very minor.
1) In terms of game play, the 40x40 base gives you an additional 60% frontage to your BCs, while 50x50 doubles the frontage (50x50 gives 25% more frontage than 40x40). This may be good or bad depending on who you are up against as you may be facing twice the number of models from an opposing unit than before. That said, you’re also in base contact with potentially that many more opponents who are now all about to be wailed on
The other gameplay factor that I can think of is templates. With the large base size you’re somehwhat more likely to be hit by a template. The 40x40 base increases the footprint of the BCs by 28%, whlie the 50x50 base doubles the footprint (50x50 gives a footprint 56% larger than the 40x40 base). This may sound all bad, however, a larger footprint also means fewer models will be under the template. I don’t think it’s necessarily a straight 1-to-1 trade in terms of a 50x50 base makes you twice as likely to be hit but your opponent will hit half as many models… but I haven’t the time or inclination to give it a lot more thought.
2) I’m much more interested in the aesthetics of 40x40 vs 50x50 bases. I had a tough time ranking up my big hat BCs on the original cav bases. They were always a little too close together and I ended up shifting some models further forward and others further back on their base to slightly stagger their weapon and shield arms (and in some cases their weapons would clash with a big hat on an adjacent model). Going to a 40x40 base gives you an additional 28% to work with for creating scenic bases, and let’s face it, the cav bases don’t leave you much space to do stuff with. The 50x50 bases gives you scads of space with the old big hat BCs to create some interesting bases. Heck, there’d be enough realestate there to build a diorama into your unit just by using up that extra space ;) The 40mm length is just enough to cover the old BC models from front to back, but there’s not a lot of overhang and if you have some heavily converted BCs you may need to jockey positions left and right for them to rank up properly. With the 50x50 base you’ve got all of the space front-to-back you had on the cav bases. Unfortunately, I think units made from the old BCs models on 50x50 bases would look too sparse (see above image), and even with adding in lots of extra scenery and basing around them they’re almost too far apart. I think 50x50 isn’t the right choice in this case, but hat’s my own opinion I realize. Other scratch built ones or from other vendors may fill out the sapce better and look OK. I really wanted the 50x50 bases to work because then I could use my old cavalry movement trays… but they won’t accommodate many combinations of 40x40.
So in my case I think I’ve settled on going with 40x40, just based on looks. They’re nicely separated, but not so far apart that they look oddly small and unable to fill out their base. The 40x40 base still gives a little more room for more interesting basing and such… and at least in my case the units would be compatible with all of my 40x40 unit fillers I’ve made for my CD Warrior units ;) Then again, I give it more thgouht and lean more toward the 50x50 again just because I can do so much more with the bases and it would allow for more interesting conversions. The Warriors of Chaos Lords on daemonic mounts all go on 50x50 bases and they’re all pretty epic (below). While the models could look like they’re on these huge bases the bases usually have other things going on with each of them that they aren’t boring. Then again, there isn’t an entire unit of them that you have to fill out
Good gravy! Hopefully this gives you all some food for thought. Feel free to disagree, or add you own thoughts here. Please save comments like “well this was a waste of time, we all new this”, etc. for a PM and just send it to me directly… I’m more likely to read it ;) :P
follow-up
Added Ogre Kingdom Sabretusks (were already covered in SoM)
Added Chaos Dwarfs, both RH era and FW/WF
follow-up #2
clarified the difference between the Sabretusk unit type in SoM and OK (as they differ).
