[Archive] Miasma's Other Plog (Eeeew Elves)
Miasma:
So my Missus wants to collect an army but she does not want to paint it, combine this with the fact that at the moment I am not that keen on T9A Orcs and Goblins and the Infernal Dwarfs (x.x) at the moment this leads me to look for a new force.
We stumbled on this deal for some Highborn Elves (:sick) which leads me nicely onto a Winter themed Sylvan Elves and my first dual purpose model, the Emerald Drake
Long way to go yet but am happy with the blocked out colours, also on the painting table for this force is
5 Reavers
5 Reavers
5 Silver Helms
23 Archers
20 SpearElves
20 Swordmasters
1 Griffon/Eagle
Did I mention how much I hate painting horses…
Miasma:
Okay so the colours for the Army have been decided here they are on a test Swordmaster, the single Green Gem is to tie the army together with the Dragon… not sure it will work to be honest
Personally I would prefer to keep either the Green or Cream from the Dragon to carry through but it is not my army, only 19 to go…
Oooh, Ichy elvsies.
A small gem probably won’t be enough to tie the army together. You might have better luck by doing the army with a colour tying them all together.
Possibly the blue of the undergarments. then add that colour to the dragon and the griffon to tie them into the army.
Jackswift:
A good start. I concur with Abecedar. The gem may not be enough on its own. If you want to keep both the green and the blue as primary colors… Perhaps bring the blue in on the dragon. Spot hit some scales with blue or consider a fade to blue from the green on some of the extremities or rounding the top or bottom of the monster. I’ve also had good luck brining alternate colors in on wing detail or using a pattern on the skin (ie. Stripes, spots, swirls, etc.). You may have to play with it to get something that really comes together.
If you alternate primary colors on units with the pop of the other color as you are using that will also make it look cohesive once you have enough units done.
I look forward to seeing what you ultimately decide to do. Cheers!
Miasma:
Oooh, Ichy elvsies.
A small gem probably won't be enough to tie the army together.  You might have better luck by doing the army with a colour tying them all together.
Abecedar
A good start.  I concur with Abecedar.  The gem may not be enough on its own.  If you want to keep both the green and the blue as primary colors... Perhaps bring the blue in on the dragon.  Spot hit some scales with blue or consider a fade to blue from the green on some of the extremities or rounding the top or bottom of the monster.  I've also had good luck brining alternate colors in on wing detail or using a pattern on the skin (ie.  Stripes, spots, swirls, etc.).  You may have to play with it to get something that really comes together.
Jackswift
Cheers Guys, Well I decided to do a small spot Colour Test, I used the base colour (pre pearlescent) of the Dragon's wings on the corresponding parts of the army (SpearElves Cloaks, Archers Bands, Musician's and Mage's sash/cape/thing?) I need a lot more colour on them but I think that perhaps it could work given a few more coats and a highlight...
Plus with that I have something to paint the shield heraldry on the Spearelves with (Crimson and Green - Dragonlord Colours)
