i’m new to this forum (found it by accident:)) and lovin it. Yesterday i’ve converted two dwarfs (1 Bfsp and 1 from 6th edition) and i just wanted to show you them. At this point i dont really like the look of there beards. Critics are welcome.
Thank you all a lot. But i must say that your cds look great too. Edit: The next two dwarfs (with the first two):
Belphagor
I am using the same mask on my Blunderbusses as the third guy here. I cut off the front of the helm. So no topknot. :cheers
If you want a suggestion, I would try to use less GreenStuff, make thinner rolls for the beard, and small length. Bringing down the size makes it look more detailed. :)
hey, very nice guys. there’s only thing, you could make better, the beards look sometimes a little bit flat. don’t press the “lines” in the beards to much, and do it also at the side of the beard pieces, so it would bring them into form ^^
Good job there Bel, good job there. I would second the beard option as the only fuss.
n00bLord
Thanks. I don't think i gonna post another pic tonight.
I just got home from work. It's been a another 9 and a half hour day again.
I'll show you tomorrow a new test dwarf.
good night all.
Either cut off the tips of the beard strands so they are flatter, or when you are sculpting them do a slight indent on the ends.
Also, I would avoid using the beard effect on the moustach. Do this as a thin bit thats pressed on in the middle, then pressed down enough so that its sticks to the beard.
