and Canix thanks for the slaves! they will surely be put to use. :cheers
Snikkers: I did some cutting on the feets, so their boots wouldn’t be too big.
I made some cutting on the arms, but I mainly used greenstuff to pose them. The heads with hoods up was a good fit from start, I just used plastic glue, the other ones needed some greenstuff.
(I also cut away the fur on their arms, and the tails. but thats pretty obvious :D.)
Clam: I actually left one of the arms on the model to the right of the champion unglued, It’s just blu-tac’ed on the photos.
Thats because I haven’t decided yet if I will use a standard or not, I’ll guess I have to play-test them first.
They look quite good, I was wondering what the stuff on the blade was, then found it. That’s an awful lot of venom on that thing :). Can never be to sure with those Dwarves!!
The Brain: yup, plauge monk bodies/ arms, and heads from common and old night goblins.
I used some pouches from the plaguemonk and old night goblin sprues to add details,. but everything else, except the things mentioned above, are achieved by greenstuff.
Perturabo: thanks for the slaves, I appreciate it :hat off
