[Archive] Naptha Bomb
Odatria:
If you take a Naptha Bomb upgrade on your infernal guard champion, is it one use only?
I couldn’t find anything in the rules saying so but the entry doors say ‘may take A naptha bomb’ but then again it also says ‘may take A pistol’ and you can use that more than once.
Essentially, fluff wise you could only throw it once, unless you had ‘naptha bombS’ but I can’t see a rule stating one use only.
It’s not one use only. It’s just a typo or little oversight in the writing. Read ‘naptha bombs’.
Odatria:
Thanks, I had guessed as much and that’s how I played it.
Does anyone regularly take them? I don’t normally but I was 5 points off my minimum core in my last game so I just put that in there, but it actually worked out to be really good, I killed two swordmasters with it on stand and shoot.
Grimbold Blackhammer:
The Champion often takes it in a unit of Infernal Guard armed with Blunderbusses. Because a Stand & Shoot reaction takes place at the longest range of the shortest ranged weapon, in this case 8", it puts the Blunderbusses into short range for the Stand & Shoot netting you more hits.
Smart ruleswranglig. I really am a complete amateur at rules. I would only have figured that out myself had I stumbled across it during a game, and maybe only if the opponent had pointed it out!
zhatan87:
Really good with stand and shoot fireglaives.
Fireglaives.
If you already have 10 blunderbusses, it’s no use.
gashnag:
The range of BB's is 12" and FG's 18" I think you got your ranged weapons mixed up with Naptha bombs in a unit of BB's you still would be at long range at 8"
I did indeed! I gotta lay off the booze.
