i was trying to register on http://www.da-warpath.com/ forums (since im also an O&G player) but for some reasons every time i try it says ‘u are not permitted to use this forum’. Anybody know the reason for this? are the forums closed or what? :mad
thats the problem, i dont even get to the part when i get an email. after filling all the fields required to register and clicking submit a text saying ‘u are not permitted to use this forum’ appears and thats it …
Hmmm. A school PC would mean it was likely that someone else got banned and took you with it. A home PC could mean your ISP assigned you an IP that was previously banned by the forum, but that seems VERY unlikely. So previous banning is probably not the cause.
Could it be that cookies or javascript isn’t enabled for that site? I’m not sure what happens if you try to register with a previously registered name either.
Can you see the main entrance to the forum but not actually use it?
I presume from your post above you see this:
Sorry, an error occurred. If you are unsure on how to use a feature, or don’t know why you got this error message, try looking through the help files for more information.
The error returned was:
Sorry, you are not permitted to use this board
Just to clarify what I said earlier, if I try and access da Warpath through AOL I get that message every time. I cannot use da Warpath forum from AOL (same with Bugmans actually, stupid AOL).
If I load it up through Internet Explorer I can use it perfectly fine.
I think the problem you have is firefox. Try using regular IE if you can.
