I am in need or one or two bodies, don’t need the arms, heads or weapons.
Paypal only, and because of the small cost I suppose a UK seller would be preferable or I’ll get hammered on postage.
If anyone happens to know of a bitz website that sells this I’d be grateful. I used to have a link for someone that did this but I can’t find it.
Basically if there is only one available I need the one that ISN’T in this picture. I.e. I need the one without scalemail on his sleeves first. If there are two available, the second one can be either of the two.
Pyro Stick:
Have you tried asking Bitzbox if they would consider stocking them? They have a stock request thread on their forum.
gIL^:
Hey Grim i only got the scale mail bodies spare. Ill give you it for free if you want it.
That would be great actually. I ‘borrowed’ one off someone else, so I’m needing a replacement. It should be fine though the only reason I wanted that specific body was as a direct replacement to keep the balance of bodies 1 and 2. Hopefully all the fireglaive arms fit both?
Thanks.
Pm sent.
gIL^:
That would be great actually. I 'borrowed' one off someone else, so I'm needing a replacement. It should be fine though the only reason I wanted that specific body was as a direct replacement to keep the balance of bodies 1 and 2. Hopefully all the fireglaive arms fit both?
Thanks.
Pm sent.
Grimstonefire
Both bodies are identical when it comes to components.
gIL^:
I sent, Expect it soon <3
