i like your thinking !!! Demi that is a great concept !!
demi_morgana:
Do you have any 'greens' to show as well?by your command :hat off
clam
Ishkur Cinderhat:
Looks like you have been working in some night shifts as well.
What did you use to cover the wheel? Looks like some modelling putty, but it’s white and shiney…?
Swissdictator:
I knew it! Demi is a cylon!!!
Nice WIP series Demi! It looks great. What is the cylinder made from?
GRNDL:
Very nice WIP pics. When you see it like this, it looks easy!
And once again proving that duct tape can be used for anything!
Swissdictator:
And once again proving that duct tape can be used for anything!I was wondering if that is what it was, but the tube seemed a bit too big. Then again when compared to those blades... it makes sense.
GRNDL
GRNDL:
I could be wrong, but I think its just the cardboard hoop at the center of the tape. At least, that’s what it looks like and it accounts for the slightly wobbly rim. It looks good, though.
demi_morgana:
sorry for no description - until I purchase another pc I have to fight for the access to internet with my gf… :~
Looks like you have been working in some night shifts as well.it’s milliputWhat did you use to cover the wheel? Looks like some modelling putty, but it’s white and shiney…?
Ishkur Cinderhat
Swissdictator
GRNDL
I could be wrong, but I think its just the cardboard hoop at the center of the tape.correct - it’s cardboard tube from scotch tape
GRNDL
snowblizz:
I’m still waiting for a (even a short) description of what it does. It is supposed to be rolling around isn’t it?
demi_morgana:
it is supposed to roll and squash the enemies but as you can see the machine is broken so 2 gnoblar slaves are doing all they can to assemble it back under watchful eye of (converted) chaos dwarf overseer master mechanic carrying converted blowtorch; and the frog is just watching
Swissdictator:
Demi: So you’ve gone green on minis… which has an interestung double meaning looking at your old work!
You could easily come up with a scenario for your creation. An experimental warmachine broke down… one side (the CD in this case) is trying to retrieve it, the other to seize it.
demi_morgana:
true, but I don’t play wfb anymore
bah - not even mordheim! :~
snowblizz:
it is supposed to roll and squash the enemies but as you can see the machine is broken so 2 gnoblar slaves are duing all they can to assemble it back under watchful eye of (converted) chaos dwarf overseer master mechanic carrying converted blowtorch; and the frog is just watchingThank you for confirming that. I saw there were several other people who were curious as well. I even voted for it at least once so I would get an explanation :) and the painting was really really good.
demi_morgana
demi_morgana:
I wrote before the story behind the model ain’t nothing spectacular
snowblizz:
I wrote before the story behind the model ain't nothing spectacular ;)Well it wasn't a story as such I was after, I was just curious if I had understood the function and purpose of the warmachine correctly. Someone mentioned it being a turbine and I thought that yeah maybe it could be but it really looks like it was a "steamroller" of some kind.
demi_morgana
