[Archive] question about the iron daemon
zhangyi:
well all i want to know is, does the iron daemon’s steam cannonade suffer the usual shooting modifiers? for example, long range, move and shoot and so on…
i think it will be useless if it suffers these penalties…cause its short range and low BS…
so what do you guys think?
zhangyi:
KramDratta:
It does not suffer the move and shoot penalties. Also, being quite a large model it (mostly) does suffer the hard cover penalty from other units.
it doesnt suffer move and shoot but everything else applies, so you are usually hitting on 4’s or 5’s. ive been told its good for killing monsters.
zhangyi:
it doesnt suffer move and shoot but everything else applies, so you are usually hitting on 4's or 5's. ive been told its good for killing monsters.
Da Crusha
well u may get 7 shoots on average, for rolling two dice and pick the highest. so 5+ hit means that it usually hits twice, and get one wound. if the monster dont have a regeneration or ward save, it will take two wounds.
but for a 285pts huge machine, make two wounds a turn... do u think it will be useful?
khedyarl:
Thing with the Iron Daemon is that it, as a single model, can pivot an unlimited number of times during its movement. This allows it to be weirdly maneuverable when it needs to. It also means that it can move six and try to get a monster within its nine inch minimum range, in which case it will blow the limbs off of most monsters.
A fifteen inch threat is nothing to sneeze at, and it’s still useful up to twenty four inches away.
Hashutcopper:
It’s quite a good unit, very resilent when hellbound. Its shooting is more effective than you think, really does blow monsters limbs off.
zhangyi:
A fifteen inch threat is nothing to sneeze at, and it's still useful up to twenty four inches away.
khedyarl
i never thought of that...but to most monsters, they move faster than the iron daemon, so the iron daemon always cant get a charge at them...so you just suggest i shoot them to death?
and at the same time, what do u think of the skullcrackers ? ur...i mean, which is better, this one or the iron daemon?
MLP:
khedyarl
I agree. It's like an organ gun that can move up to the target, shoot it in the face then tie it up in combat.
@zhangyi: Don't try too hard to get it in to combat, it's too unmaneouvrable for that. If your opponent makes a mistake and you get a charge then go for it! But I think it's best use is to do what I just said above then get in the way. It should be a great anvil unit while you organise a counterstriking flank.
zhangyi:
khedyarl
MLP
yeah now i know the role of the iron daemon, so compared to its cousin, the skullcracker is a killing machine to the enemy's elite infantry, right? just charge it into close combat to some elite troops and then watch for the result. do i get it wrong?
sorry for that many questions, but i'm a green hand to CD~thanks for answering!
Border Reiver:
khedyarl
Unfortunately no, it cannot pivot during movement. The Lumbering special rule prevents this. You can pivot before you start to move, then move straight ahead, but then you're stuck til the start of your next move phase.
It's still useful, but requires carefull positioning during deployment to minimize the need to pivot. I like to put it on a flank and send it towards the enemy warmachines, your opponent will only make a battery once if you do this.
khedyarl:
Border Reiver
You may want to review the Lumbering and Unstoppable rule.
"It may move normally up to its move distance and fire its weapons without penalty while doing so. Alternatively..."
The Iron Daemon is allowed to move like any other individual model as long as it doesn't engage the boiler, and as an individual model, it is allowed to pivot an unlimited number of times.
In addition, if you do engage the steam boiler, there is no provision for pivoting at all, so you cannot pivot before moving or after if moving the additional 2d6 inches.
The Daemon's a tricky unit to work with, its best role from my experience is as a monster hunter-killer. The fifteen inch threat really does make a mess of opposing monsters, and given that it has a total twenty four inch threat (all assuming that it doesn't user the boiler), it's going to be firing from turn one onward.
In addition, if you manage to have a Daemonsmith (or Prophet, if you're so inclined) with the Lore of metal Enchanted Blades spell, the Daemon will absolutely ruin opposing monsters (and units of ogres).
Ogre_Mage:
khedyarl
I usually go with Fire, that way my Prophet makes the target flamable, then I can Fireball/Flaming Sword of Ruin things to death. But +1 to hit is nice too... hmm
KramDratta:
Was looking for somewhere suitable to post this & found this topic.
Sent: 08 June 2012 12:07
Subject: Re: Rules query
Hi,
Thanks for your e-mail. The Iron Daemon is not a War Machine as stated in its troop type; as such it does not benefit from the Infernal Engineer re-roll.
Regards
Forge World
If you have a query about your order, please call
0115 900 4995 within the UK
011 44 115 900 4995 from the US and Canada
00 44 115 900 4995 from much of Europe
Our office hours are:
0900 �?" 1800 (GMT) Monday to Friday.
0900 �?" 1700 (GMT) Saturday.
KramDratta:
Forgeworld are on fire today !!!
Sent: 08 June 2012 12:52
Hi,
Thanks for your e-mail. The wording on pg193 is intended specifically to divide the Iron Daemon’s attackes from those of its crew, which are not affected by the Hellbound rule. Its shooting attacks are affected as per pg175,
Regards
Forge World
Far2Casual:
Funny.
The Engineer works on a Hellcannon but not on the Iron Daemon…
KramDratta:
Funny.
The Engineer works on a Hellcannon but not on the Iron Daemon...
Far2Casual
Yep but at least its shooting is magical. Hello Ethereal Slann & Hexwraights :)
Ender SpiteSworn:
KramDratta
Well there is some debate about that. Wish they would have addressed it in the FAQ.  Its been gone over pretty throughly before though if you want to go track the thread down.
I do love my iron demon, It absolutly eats Ogres, Chariots, monsters, and does a fair job at warmachines as well. I never really get to charge stuff, but the shooting and T8/W8 unbreakable offer a lot tactically
KramDratta:
@Ender Spitesworn: Not anymore :slight_smile: read first post.
Ender SpiteSworn:
@Ender Spitesworn: Not anymore :) read first post.
KramDratta
Awesome, Thanks! would have been nice if they bothered to include this in their latest FAQ...
