TrudiFurioso:
Hi Fellow BullWorshippers
Here to ask your aid once again. Does those looks like recast to you?
I cannot tell myself, but those excesses on some models tags does look suspicious to me.
Thanks and Hashut may bless you All!
TrudiFurioso:
Those are definitely recasts.
TrudiFurioso:
Those are definitely recasts.Hey Fuggit! Thank you for the aid!
Fuggit Khan
The altered tags along the bottom are the biggest giveaway, clearly new ducts for pouring (or injecting) the base metal were added. Also the flat "blade" surface of some of the hand weapons show obvious pock marks from degraded cheap molds. And some of the original mold lines that would be visible on an original miniature are missing, which is evidence that the mold lines were cleaned up from the original, before a new mold was made of the model.Those are definitely recasts.Hey Fuggit! Thank you for the aid!
Fuggit Khan
Just to be more aware, from what you can tell that those are recasts?
TrudiFurioso
Sjoerdo:
Also the flat "blade" surface of some of the hand weapons show obvious pock marks from degraded cheap moldsAgree with everything else, except the pock marks most likely come from using too much talcum powder, which is used as a a flow agent (I've done quite some gravity casting myself so I know when this occurs).
Fuggit Khan
Horace:
I think the detail looks a little soft on them as well. There are quite a lot of hobgoblins on ebay which are blatant recasts. Mainly from Spain in my experience…
