Hey guys! I have a metal model full of edges & spikes (veeeery easy to chip), so I must seal it! The problem is, how? Which products to use? I never sealed a model in my long career of hobbyist :o! So please, help me out! I am based in Europe, which means that I am not willing to pay costly shippings from Down Under or the States ;P!
For more than 30 years I’ve used Testors brand ‘dullcote’ lacquer spray on my models. Simple shake and rattle can, works great and none of my models/miniatures have ever chipped.
Thank you guys! How do you use this product though?
A ) First a gloss lacquer, then Dullcote to kill the “shininess”? B ) One single light coat of Dullcote, in a sunny day, holding the can far away from your model? C ) A thick layer of Dullcote?
Gloss coats on models is only needed if you are applying decals. The gloss finish (along with decal solvents) will eliminate the decals from “silvering” from air trapped below the decal. No decals being applied? Then don’t bother with gloss coats. Room temperature works best, apply two light coats, allowing about 15-20 minutes between each coat. Don’t hold the can too close, will cause runs. Not too far away either, will cause what hobbyists call “orange peeling”, basically the spray will dry in mid air if held too far away, so it causes a lumpy effect, which looks exactly like the texture of an orange peel.
Gloss coats on models is only needed if you are applying decals. The gloss finish (along with decal solvents) will eliminate the decals from "silvering" from air trapped below the decal.
No decals being applied? Then don't bother with gloss coats.
Don't hold the can too close, will cause runs. Not too far away either, will cause what hobbyists call "orange peeling", basically the spray will dry in mid air if held too far away, so it causes a lumpy effect, which looks exactly like the texture of an orange peel.
Fuggit Khan
Darn. Sounds complicated. Anyway, Dullcote is actually sold in UK stores, but the law doesn't allow them to ship cans overseas (dang)... And I am having a hard time in finding the product in German shops. Any other brands? Fellow European users???
I don’t always seal (not always a fan of the result on a finished model). Only selectively depending on the model usage. When I do I have used brush on Matte Varnish by Golden. Paint on works better here as half the year I cannot spray outside due to winter temps (even prime with acrylic gesso to keep the brush on theme). Just make sure the bottle is well shaken/mixed and test it on something first to make sure it will come out how you want it. Unmixed or too heavy a coat and you start getting a shine which is annoying and hard to get rid of (without spraying on a coat of testors dullcoat which is my go to spray varnish when I have to spray). Cheers
Thank you for your feedback guys! Unfortunately I can’t find Dullcote here in Germany… But I found Vallejo Gloss & Matte finish. Has anybody got experience with these???
