LumpinCroop:
got a buddy thinking of playing these guys. He had a few rules questions.
1. Do you use 5-man ranks with Ogre Kingdoms models?
2. where are the rules for rhinox cavalry?
3. the high points cost seems to weigh againgst the Ogres in terms of combat resolution. Is this a problems when they are played?
BLOOD AXE:
Maybe try Ogrestronghold.com
Servius:
depends on how he plays honestly… I have run units of 9 ogres… and ran them so that the 3 impact hits i would get would hit at ST6 causing a wound most of the time… the ranks can be an issue but usually if you can build the list to hit hard enough on the charge to matter you should be good… I also rely on gnoblar blocks to allow my ogres that get stuck in combat a chance to break a unit later by getting in a flank charge.
