[Archive] The Word of Hashut - Issue #2
I tried it on both Mac and PC on Firefox and it worked. In FF open it and THEN save from FF to your computer. Should work just fine that way.
With that being said the download link should work simply by clicking on it, I’ll check it further.
Bladed Raven:
It does not seem to work on my laptop. But I can download it at school and it seems to work fine.
Bladed Raven
Its a big PDF. What is your connection speed of your ISP at home: dial-up, broadband or DSL? if your speed is slow (which based on what you described may be the case). You can try downloaded the LR=Low Res version, it will look find on screen but is significantly smaller in terms of size, caution it will look bad should you try to print that version.
To be on the safe side I have re-uploaded the PDFs to the site, if anyone has any further issue besure to PM me so I can look into them.
It would be worth saying how big the file is next time. Fortunately I was on a super fast connection to download it this time.
Yeah That is why this time around I included the low res version since its significantly smaller. I’m also thinking about compressing it own quite a bit as well.
Auretious Taak:
If you can compress it abit that would be great, seems my comp doesn’t like downloading it for some reason, I may have to try it at uni on one of the connections that is relatively fast and save it from there.
It is already compressed:
try this one to:
http://www.chaos-dwarfs.com/pdf/WOHIssue2LR.pdf
Merchant:
Hello, Admins - I have question question: is the WOH Issue(s) released every second month or 3rd or???.
- I’m looking some much forward to the next one, and I have not been able to finde the anything about the release…
Viskar Zhragoth:
Merchant,
Check with Willmark, since he is in charge, but I think it is out towards the end on December…and the current plan is once every three months…AFAIK.
Viskar Zhragoth
Merchant:
Merchant,
Check with Willmark, since he is in charge, but I think it is out towards the end on December.....and the current plan is once every three months....AFAIK.
Viskar Zhragoth
Viskar Zhragoth
Oh :) Okay thanks my friends - I cannot waite till the end of december, this is much bigger then GW's White Dwarf (well in my opinion)
Cheers :cheers
Merchant- Basically the pattern is every three months making it a quarterly, issue #3 is due out on the last Saturday in December, which I believe is the 27th. Issue #4 is already starting to be planned and is scheduled for March.
Also if you liked issue #2 I’m sure you’ll like #3, it looks good, or so I’m told…:slight_smile:
Borador:
I can’t open it, high resolution give an error which says the file is broken and couldn’t be repaired, the low resolution gives a 404
Try clearing your cache.
I’ll take another peak at it tonight, so on your side of the pond check it in the am.
I did not an issue with the LR version which is now fixed.
Borador:
seems to work now, thanks ^^
No worries, just curious did you try both?
