Dînadan:
Just found out that the plastic castle kit has been put out to pasture:
http://www.games-workshop.com/en-GB/Warhammer-Fortress;jsessionid=0404EED8DEA5D8FF2ECA97DC94A71F0E
Dînadan:
Doombeard:
There’s a list of other non scenery stuff published today going extinct soon from the Empire and WoC ranges , things like Marauders and Chaos Warriors etc , don’t have the link to hand but its over on Warseer
Typical GW procedure. I have no idea why they do it.
They did it with dreadfleet and I would have bought one when I’d saved up enough
Dînadan:
I expect we’ll get a new one to tie in with AoS, but this one will have skulls for the crenels and the gatehouse itself will be a giant skull. Oh, and each wall section will have a dozen regular skulls dotted around in place of bricks. And one section will have a big chunk missing from the outer layer of bricks revealing it’s crammed full of skulls. And it’ll cost £200 and will get pulled without warning 11 months down the line.
Doombeard:
buy one from this guy, way way cooler than the GW ones
http://www.ebay.co.uk/itm/WIZARD-TOWER-WARGAME-SCENERY-28-SCALE-UNPAINTED-/261910694737?&_trksid=p2056016.m2516.l5255
Dînadan:
I’d be a bit worried about using that in games - the info below says its ceramic; one accidental knock/drop and it could shatter if it falls far enough.
Zuh-Khinie:
You forgot that all skull-shaped doors and gates will have skulls instead of handles…
DAGabriel:
…and they are decorated with skulls!
Doombeard:
I'd be a bit worried about using that in games - the info below says its ceramic; one accidental knock/drop and it could shatter if it falls far enough.I'd chuck it on a base with some nice stuff around it , bit of mdf or ply. You seen his castles? so badass!
Dînadan
Dînadan:
Still doesn't help with the accidentally dropping part as you're setting up.I'd be a bit worried about using that in games - the info below says its ceramic; one accidental knock/drop and it could shatter if it falls far enough.I'd chuck it on a base with some nice stuff around it , bit of mdf or ply. You seen his castles? so badass!
Dînadan
Doombeard
Doombeard:
True! Fragile stuff! Shame he makes it that way!
I reckon he’s available for commission work. Imagine getting him to make a ziggurat or something, would be great!
