As my avatar would say impressive, most impressive.
This awesome tutorial has been noted…
Nicodemus:
I’ve been SO nervous about spraying the matte finish coat on them and seeing them disintegrate before my eyes (this has happened with some 40K interiors I made) that it’s been almost two weeks since I finished everything.
I can happily report that everything got a finishing coat and there’s not the slightest sign of trouble at all (I’m using Krylon Matte Finish).
FYI: It was nice and warm outside tonight and not too humid so things would dry reasonably quickly. I applied a very thin coat to all the sides of the bases and then a quick thin pass over the tops and into corners, etc. After waiting ~5 mins (the spray can said 10 mins, but I get impatient) I sprayed the sides of the bases again going a little more slowly and then did the same with the tops. After it was looking mostly dry I applied a third coat to the top surface of everything (as it’s going to get some wear).
So there you have it… don’t be shy to use the spray cans, especially if you have put on several base coats and then more paints on top. Of course you always want to test the finish sprays to see how bad they’ll chew things up and then work accordingly. I tested on some scraps of bare foam and I couldn’t see any problems with the Krylon finish. With that on the surface I think it’s pretty safe to move up to stronger clear coats as well if people wanted to.
Next stop is the Chaos Dwarf Objective room and Dungeon rooms :hat off
P.S. One of the things I forgot to mention previously (speaking of being impatient) is that when I’m doing my base coats or any other stage of painting I have a high speed floor fan going. As I finish off applying a coat of paint it goes in front of the fan so that it’s ready ASAP. Just a little trick that helps keep the pace up… especially if anyone else out there decides to base coat every WHQ tile ever made all in one night ;) Be warned though, these foam boards are light and even the big ones will blow away if they’re too close to the fan, tumbling across the floor spreading black base coat with them as they go
GRNDL:
The trick to insulation foam is to use acrylic house primer or other kind of acrylic paint before painting, ie, as a primer. It seals the styrene and won’t allow the nasty propellants in spray cans to eat at it.
Bassman:
Impressive and… impressed!
I use unsulation foam for basing, like rocks and stuff like that. Me too fear corrosion so I alwas “seal” the foam with vynilic glue. It does the trick for me.
I have to say I do noe make massive scenery like yours, just a few bases for my Dhawi Zharr.
Loki:
Awesome amazing work :o You have got them looking just like the card tiles with the correct lighting and colours but yours are a million times better what with being 3D, Quirrik’s Lab has to be my favourite
Taedae:
I am completely speachless. These 3D boards are completely awesome. You got me wanting to make me own set of them. Great pics also. It all looks so life like.
Nicodemus:
Putting the finishing touches on the project…
Since my squares at 50% larger than the original ones all of the original tiles are too small as well.
I scanned in all of them at 600DPI and then resized them to 150%, printed them in colour and mounted them on cardstock. I figured this was also a good time to make extra copies of them as well, like the treasure chest, pile of bones, and spiked pits…
Here’s the final version (compare with the image above):
Never mind the unfinished paint jobs on the minis… the tiles just give a sense of what things will look like in-play:
don’t worry about the Wizard, he’s levitating
Because some of the entrances to the dungeon rooms are not at the same height, such as the Fighting Pit, the stairs, or the shaman’s den from the Lair of the Orc Lord expansion, I needed some way of elevating the other dungeon tiles to keep things lined up.
These were recycled from a tower I was building and decided I didn’t like the look of ;) Here’s the start of my circular support columns (some doorway supports are shown on the right as well):
turquois dwarf:
I realy like these rooms! the pillars are a good idea.
could you put the file with the counters on this thread or would there be copywrite/file size problems?
I love this thread. Keep it coming.
Nicodemus:
could you put the file with the counters on this thread or would there be copywrite/file size problems?I'm honestly not sure, but I assume there would be, and I don't want to cause any fuss with being seen as distributing copywritten stuff via the forum.
turquois dwarf
That reminds me of the people who sell something as “Xbox 360” and only partway through the description does it actually say “This is for the box of an Xbox360 only, the Xbox is not included”, so someone pays $200 for a cardboard box because everything else made it look like it was the whole lot.
Bare in mind that he is selling a single card, which is $9 on its own, plus at least $9 in shipping! Ouch. Must be printed on gold or something.
The description of “near mint” is rather amusing too.
Never had the chance to play this game myself - but I love your passion for this OOP game.
Your 3D tiles are awesome - and there are some very nice hits and advises in here - to be used for terrain building in generel.
Keep up the good work.
Nicodemus:
Forgot to post the finished Sewer tile from White Dwarf:
Here’s a quick & rough example of the support pieces for getting some quick height built up off the table:
(The door is from the boardgame Dark World)
The last thing I’m working on that’s going to be a longer term project are themed Warhammer Quest doorways to go with each Objective Room tile.
Here’s the plan for the Tomb Chamber:
The miniature on either side of the doorway, in case it’s not clear, is a kneeling/praying paladin, from Reaper Miniatures. I’m planning to paint them up as statues…
Some of the older minis from games like Dark World, HeroQuest, and especially Battle Masters have somewhat static poses, but that means they make stellar statues.
Here’s a good example that would make a decent statue, a Halberdier from Battle Masters:
Battle Masters goes for pretty cheap on eBay and has a ton of stuff. I think the Battle Masters Goblin Wolf riders might also be useful for Hobgoblin conversions in a pinch, at least the wolves are usable.
Once I start on my Hobgoblins I’ll see how it goes. The Battle Masters plastic for the green skins (green plastic) and some of the Empire troops like the Crossbowmen (red plastic) is pretty brittle and things have a habit of cracking or snapping where you don’t want them to while you cut (at least mine do), This is in contrast to the grey-coloured Empire Halberdiers that came with that set, which are about the same consistency as the BFSP plastics… Oh, and all of the horses that come with that game could possibly be converted into shorter-legged bull centaurs, although I haven’t tried this!
I believe Vexxus’ Chaos Dwarf Molten Stronghold uses the Battle Masters tower… very nicely done. Battle Masters auctions usually have these towers missing as keeners usually pilfer it for other projects
Wow like the doorway
Taedae:
god i cant wait to get my warhammer quest in the mail. i so want to make this stuff myself also.
turquois dwarf:
those pillars work realy well. the themed door is also very nice. are you using normal games workshop paints for these? it seems a large area to cover with such a small pot
Nicodemus:
those pillars work realy well. the themed door is also very nice. are you using normal games workshop paints for these? it seems a large area to cover with such a small potNo, there's no way I could afford to paint these with GW paints. I use acrylic paints from a craft store. They aren't the cheapest ones, but not the most expensive either. From what I've found the cheap ones have a lot less pigment in them and when you mix a few colours together everything starts to look grey-ish and you lose contrast. With higher pigment you can do a lot more mixing. The GW paints have a lot of pigment in them, which is why colours can still look striking on a small scale.
turquois dwarf
turquois dwarf:
I will have to look for these paints. At first I tried using poster paints for terrain! this was a very bad idea because if you tried to hilight something the paint wets the previouse layer and they all blend together to make one couler. i had to paint a tower i undercoated black “white” just to get a dark grey!
Taedae:
. Oh, and the brand of acrylics I use is "Craft Smart" with I believe is a Michael's store exclusive, but I could be wrong. I also have some "Americana" brand colours for doing lava. Toward the end of the project I picked up a few others from Michael's craft store that were on sale. They are "Apple Barrel" brand acrylics, 60mL of paint for ~$0.75 each... but I'm really not happy with them at all, much less pigment in them and I don't think I'll end up using them again. Even mixing the Apple Barrel white with other colours like green or brown made everything grey.do you like these paints? do you use them on minis also?
NIcodemus
Nicodemus:
I will have to look for these paints. At first I tried using poster paints for terrain! this was a very bad idea because if you tried to hilight something the paint wets the previouse layer and they all blend together to make one couler. i had to paint a tower i undercoated black "white" just to get a dark grey! :)I keep a high speed floor fan propped up next to my dungeon painting area so that each layer dries as fast as possible. This way you can apply the next layer of paint as soon as possible... but you're right - you have to wait for coats to dry before applying successive coats, (especially if you're dry brushing).
turquois dwarf
do you like these paints? do you use them on minis also?I like the paints fine, for terrain... never for minis. I tried painting a few barrels with some of the brown acrylics and there just isn't enough colour to make things stand out.
taedae
