Ancient History:
Thread title says it all, really. What do you feel is missing? What do you feel most needs to be changed or updated? What do you want, wiki-wise?
Ancient History:
furrie:
the thing I’m missing isn’t allowed there, because I’m missing the rh list
Borador:
More about chaos dwarfs in the northern lands and snowcovered areas. (Uzkulak anyone? (aa) )
The issue there would be with canonicity. As far as I know, there’s no information about those regions in any published material.
Ancient History:
Not much. A little.
Tarrakk Blackhand:
Is there anything missing? I thought the Wiki was quite thorough…except for the RH list.
I can’t seem to upload files to the wiki. Anyone else having trouble?
Great another issue from the move? What happens when you try to upload?
I would like to see a strategies section filled with links against particular armies, added to the main page right next to Models. I know that a strategies page exists but I find it sometimes and then I cant seem to find it the next time I look.
also strategies against new army books labeled 7th ed, and perhaps leaving links to older strategy articles with a subtitle 6th ed.
Great another issue from the move? What happens when you try to upload?It tells me it cannot copy the file to the location. I've tried with all the various image types.
Willmark
Ancient History:
[[Chaos Dwarf Tactics]], the list of links is near the bottom. That is a pretty big page, I'm not sure how exactly to split it up.
Da Crusha
Is it only the images? Can you update text?Great another issue from the move? What happens when you try to upload?It tells me it cannot copy the file to the location. I've tried with all the various image types.
Willmark
cornixt
I can update text fine. I was adding some new banners and got the banners page set up, but when I tried to upload the pictures it wouldn’t let me. Looks like a permissions thing in some way.
Sounds like the file permasions are off for the wiki I’ll look and see. Off hand do you have the path to them? If so please send. If not I’m sure I can find them.
