TheHoodedMan:
What do you think?
I`ve got a warmachine heavy list with a lv4 and two lvl 1 on foot against wood elves (2500 pts).
What lores shall I use?
TheHoodedMan:
What do you think?
TheLazySamurai:
What do you think?I would lean heavily towards Hashut with the level 4 and Fire with both level 1 wizards. Death and metal don't exploit the weaknesses of the army the same way these lores will. Wood elves is one of the few armies with flammable units, so spells that do flaming damage are obviously a good choice, but they are especially good with +D3 to cast. Burning Wrath and Flames of Azgorh work very well against trees of all kinds. Ash storm will block needed charges, but also cause -2 to shoot on a horde unit of archers if needed. The other spells in the lore aren't useless, but the three above are what I would be looking for when generating spells.
TheHoodedMan
TheHoodedMan:
Thank you for sharing your knowlegde. Fire on the lvl 1s will definitely be the first choice.What do you think?I would lean heavily towards Hashut with the level 4 and Fire with both level 1 wizards. Death and metal don't exploit the weaknesses of the army the same way these lores will. Wood elves is one of the few armies with flammable units, so spells that do flaming damage are obviously a good choice, but they are especially good with +D3 to cast. Burning Wrath and Flames of Azgorh work very well against trees of all kinds. Ash storm will block needed charges, but also cause -2 to shoot on a horde unit of archers if needed. The other spells in the lore aren't useless, but the three above are what I would be looking for when generating spells.
TheHoodedMan
I usually go Fire on my level 1 regardless of opponent, but wood elves are a great choice for lore of fire. My first choice of spells is always the Flaming Sword if I can get it. I use it to buff my blunderbuss, but obviously your wood elf opponent is not going to march directly in front of such a unit. It can still be used on your warmachines with the Deathshrieker being a particularly good choice. Large template wounding T3 on 3s and the big rocket being made to cause flaming hits would obliterate a treeman with 2d6 wounds :o Fireball works great for clearing the amount of chaff you are sure to see across the table. Small units of T3 fast cav hate 2d6 S4 hits.
Anyway, that's my vote for spell lores against wood elves. Let us know what you decide and how you fared :cheers
The Lazy Samurai
TheLazySamurai
TheHoodedMan:
In the end I thought a little about the wise Samurais Words: Why not take 3 fireballs instead of two ;)?
The high range of the fire spells proved to be very valuable. Both the fireball and the flame cage spell were very effective. In combination with some channelled power dice one spell per turn was always on target.
Here are a few notes about the battle:
http://www.chaos-dwarfs.com/forum/showthread.php?tid=15813&pid=261491#pid261491
