Got it off of Reddit. I recommend opening in a virtual desktop because it is a .exe file, but here is the link:
And if you cannot get to Reddit here is the dropbox link:
https://www.dropbox.com/s/rg9df8aayg38vpa/BBEditor.zip?dl=0
This is a zip file with everything you need included. I’ve included example files, but everything should be mostly self explanatory.
1- Unzip to where you want (no installer needed)
2- Install the fonts in the “BBEditor Required Fonts” folder
3- Double click mse.exe to run
A couple notes:
-The editor has a “Style” button. Pressing this will bring up the options to show or hide the print bleed.
-The file menu has an “export” function. If you do an “export all”, you have to choose a name to use. The default “card.name” option will not work.
I’ll watch the thread an answers questions if I can.
