Hi all,
The great D6 wounds host just revealed his new Chorf army, a must see!
I really like his battle reports so looking forward to seeing them.
Lovely army but some of it i find disturbing! The paint is far too high up the brush again and again :mask:
Finally painted a whole unit. I should be able to paint lava this weekend.
Some great ideas! I respekt classic goblin green basen but I really think bark basen are just a better fit.
Hyped about adding a unitnof 3 badland Ogres. Lol I love good hype. Especially when I came up with na idea to use some Mantic Ogres. I also should have their plastic Ogres too to film that gaps im ranks
… and some lava progress on sneaky gits. Some black drubrush and painting streaks of bright lava are left to do. And I will call them done.
As always, impressive results :smiley:
Quick question, how do you do the lava reflection on all the minis, just a very well executed and precise drybrush, or some kind of effect paint ?
I use the same colours I use to paint lava (starting with dark red paint) spayed from heat/light source direction (so from below). I just follow one rule. Closest areas to lava are almost as bright. The more distant areas are less and less bright.
Is this what you asked about?
It is, thank you ! I’ll experiment with reflection like this !
MY advice is it is better to add OSL slowly.Those are TT models, so I was not very focused on perfection but it is easier to add more when 1st layer dries than over spray.
Done. I hope to do better pictures and edit them soon.
I has this idea for some time now. Abyssal dwarfs from Mantic has 2 hounds on their sprues. I wanted to Build one as a ‘musician’. There are great STL upgrades to build a dwarf musician but a howling hound feels morę interesting. And it took me 15-20 minutes to paint it!
Red oil is still wet do it looks wierd but it is 95% done.
I am looking for Fabelzel’s armoured orcs model stl as they dissapeared from google drive from a different topic. Anyone has those? I need a Big Boss model :smiley:
I think a small mercenary ogre unit sounds fun so decided to mąkę one. I really like small projects like this.
Half way painted.
These looks great, hope they’ll function well in the battlefield !
Decided to do final highlights AFTER lava so I save time painting things I would then cover in red :smiley:
I should do them in 2-3 days when I find time.
Progress lava makes models Look good. 2 morę layers left.
Ok. Decided I will stop painting here. Some belts and buckles are not fully highlighted. I could do other things too but this supposed to be TT+ so… Done.
Hound-sician for my IG.
