Yo! This morning I had to finish one of the 2 AoS CD while my brain decided to do something else entirely because I can’t fucking stick to the plan
I printed a wall section and from that I started to bulk it up so I had a solid base to work with
And so far I’m here! Now I’m going to a concert as Carcass are going to play nearby so I’ll continue in the next days
Love the step-by-step pictures! Super helpful to see your process
Glad you find my mess helpful ahhauaua
I’m just doing random things, going with the flow as usual hahshahah
Yesterday I quckly made the 2nd wall, I’ll add planks tonight for structure and more interest
shit is starting to look like something! done for the night
Although I almost finished it, here are the WIP pics of the last 2 days
The pink stuff is a mix of so much shit I had laying around:
Plaster/stucco/gesso call it whatever
PVA + water
Fine and coarse sand
Wooden bits due cutting coffee sticks
Beard hairs
I didn’t like how then ground level looked so I removed it and made a thick sand level with some mid showing through close to the sewers
If I would redo such display, there are already many things I’d change, and I might so so at some point as i find very relaxing those kind of works
Grazie jasko!
Didn’t make many progresses those few days
Paint is now mostly done, I have to add some yellow tones to the moss and remove a bit of rust from the grate, also I’ll have to add static grass and few tufts and leaves here and there. All in autumn colours
Also this was the test piece (as random scatter) with all the leftovers where I could try the effects before going on the main piece
This already looks very cool
