I’m working on a big mob of greenskin slaves, mostly using old goblin regiment boxes I pick up on ebay. If you’ve worked with those boxes you’ll know… there are never enough torsos.
Have any of you guys seen a stable source of decent, goblin-sized torso and leg bits that can be had without the rest of the kit?
The torsos are a separate part and quite compatible. The actual box is a treasure trove of bits but failing that you could scour eBay for skaven night runner and goblin torsos to make up the difference.
Not any more they don’t. Thanks, Oxy! They’ll need a teeny bit of work because the head connection format on the old gobbos is torso-male to head-female whereas these are more modern. But I can manage that with sprue goo and concealed putty.
Yeah a little ball of putty as a “neck” would be fine and it wouldn’t have to look perfect as it would get covered straight away by a head. Look forward to seeing these @chitzkoi
I’ve sculpted my own out of greenstuff. They look terrible up close, but with arms and head attached, at tabletop distance you really don’t notice at all. A torso is such a very basic shape, it’s hard to get it too wrong, and with proper body parts attached you don’t see much of it anyway.
