The Excellence of Shamash : Flagellant's Chaos Dwarfs
These is something wrong in the concept of the original Death Rocket miniature. If you check the elevation mechanism, if you place the rocket in the regular position, you can’t elevate the rocket, you can only lower it. Like orizontal position is the highest you can get. This always puzzled me.
Another point: Death Rocket is suppose to make a big loop over the battle field and then crash upon our enemies (hopefully)…in my (wicked) mind it should be pointed to the sky in the direction of the enemy. A sort of indirect fire machine.
Like the Soviet Katyusha rockets…
aBattle_of_Kursk_6
Hence the idea to invert the rocket position :man_shrugging:
I think you are right. The model presents so much better with the mechanism in front. The Earthshaker also has it’s raising mechanism in front, so it would be consistent with that. I realize now the issue of recoil doesn’t exist. It is not a cannon with a charge that expels the projectile. Assuming the little vents let out the blasts well enough (honestly they should have just made it a holder tray like the Katyusha), there isn’t any recoil.
Our only issue with the model is the mechanism being on the wrong side for the dude aiming it. Perhaps the marvels of 3d printing or conversion could help with that?
Precisely! My personal theory is that this was actually the sculptor’s intent and it was simply assembled incorrectly at the studio. However, for that to be true then the classic Mark Gibbons artwork would need to have been drawn after the sculpt was complete, and I have no idea if that’s true.
Korean and Chinese ‘fire carts’ (the real world analogue to the Empire Hellfire rocket launcher) follow the same principle.
I find @Bassman’s reasoning certainly convincing, so sign me up as a follower of the inverted launcher. Not sure though if it was intended by the sculptor. The carriage looks too close to that of a classical cannon. My personal guess is that whoever designed that just was not aware / did not care about Newtonian mechanics.
Rather, sculpted a cannon and decided: Rocket is even more boom!
(You don’t need deeper physical knowledge for this. Even a cannon needs some elevation.)
I’m more surprised that FW’s Death Shrieker successor still fired horizontally to the front.
First contact with Chaos Dwarfs invariably begins with bloodshed, so when Ginëladan and his army first landed in the new world it was only through Mut-Ashkur’s cunning that both factions didn’t promptly annihilate one another. When his hobgoblin scouts first reported the arrival of his curly-bearded cousins it was immediately obvious that they were no ancestor worshipers, for they had subjugated greenskins working for them, so he took great pains to study them.
It rapidly became clear that the height of one’s hat was of great importance, for all orders seemed to flow from high to low. Inspired by the great towers he saw aboard the foreigners’ vessels, and being great stonemasons themselves, they began a construction like none before. Not only would this hat tower above the others, it would have a second helmet on the top of it (to say nothing of a second dwarf)! Whether the second helmet should be considered for total height would be a matter of scholarly debate for centuries, however there was no question of it’s authority when he first approached the invaders.
Such was the awe it inspired that he was immediately brought before Ginëladan where negotiations began that would forever entwine the fate of their Houses.
Marvelous painting on one of the best models in Chaos Dwarf history. Great flavor text too!
Awesome model. Fantastic story!
man where does this fantastic model comes from?!
also i’m so proud to see your brown beige colour scheme on those bighats, an amazing rapresentation of our community and great race.
i love it so much!
So I was trying to complete the lore (and more recently banners) of units before posting them here, but that is just slowing down the already very slow process. So here’s a new year update!
I was not terribly productive in 2023 all things told. I tired of my brush-on primer and spent some time experimenting with alternatives. I dislike rattle cans because they only work half the year here and you can end up with a fuzzy primer job if you you do anything wrong, so I had a friend try a couple alternatives through his airbrush. I settled on Stynylrez in the end but could hardly expect my buddy to prime my whole army for me, so I ended up grabbing a compressor and a cheap airbrush. I’m still figuring it out, but so far it’s amazing.
One thing I did do was start a Chaos Dwarf army for Warmaster Revolutions! My flgs has a group that has picked it up and I had to join. I’m relying entirely on zenithal highlights and AP speedpaints and it’s been a great lesson in accepting “good enough”. At 10mm I simply can’t worry about every stray brush stroke. And even just trying a newer method like zenithal has taught me a lot. I’ll have a blog up for those in due time as well.
My final update, which is actually pertinent to this blog, is finally finishing off the unit of Adad-Usur’s Consul Corp (axes), adding some unit fillers, and completing Ginëladan himself! I’m working on the banners and lore still but want to get them up in the meantime.
Here’s to a productive 2024!
Loving the beeg mushroom men, these would go well with the lil ones I sculpted for the Turnip Bastard!
Behold, Demithrizhu kin Shamash of Golden Hat XLIII!
If it looks like I haven’t drawn anything by hand since 6th grade, it’s because I haven’t! But I tried to make it interesting anyway. Older heads will immediately recognize the model chosen as @Fuggit_Khan’s Standard Bearer. I forgot to include a side shot in the entry to highlight the incredible hat on this bad boy, so here’s a new one:
Truly glorious.
As for the banner itself, I found this design in the same iconic piece I take my pfp from:
My first step was to trace the original and fill in the parts that were covered by the horn in the photo:
It was too large for my banner, however, so I had to freehand it smaller. Then I threw our rune in the bottom corner to try and make it look less off-center (yes, my best take wasn’t even positioned properly :skull:) I also tried to give it a black and white, jagged border like the original but it ended up looking odd against the more yellow tones of the paper so I just gave it a brown to match the rest of the army.
I think if when I redo the banner itself I will try and find a way to make it bigger, and so more grandiose, but for my first try with a paper banner I’m pretty happy with it.
Also, if anyone with more skill than I tries their hand at the original, please send a scan of it my way!
That’s a very cool piece of artwork. I like your version even more now seeing the origin. Anvil Hat will forever be my unrequited love… at least I have my fuggitzooka to sing me to sleep at night.
The guy on your banner would be a super cool concept for a sorcerer too. Perhaps in a perhaps soon Artisan’s contest perhaps.
I definitely don’t…
Have a habit of…
Spoiling the future on this blog and then entering it in a contest.
"Fire elementals? In this bog? Bind me something that will survive it’s first encounter with a puddle!
-Ginëladan kir-Shamash
Almost forgot to post these guys! I present my entry in the the last Golden Hat, the K’enoki Earthborn!
I had a lot of fun with these guys. I experimented with GSW’s copper patina on their armour (not a big fan), as well as mixing some color into the puddle on the “manburner’s” base (big fan).
I purchased these back in 2022 from a Kickstarter called “Tales From Apocrypha - Wave 1” while I was hunting for mushroomans as unit fillers. When I found these I knew they were bound for K’Ddaii-ship, so I purchased 2 Enoki Sporesingers and 1 Enoki Knight.
It was an ambitious little project. These were cast in resin, but it was evidently too weak and suffered greatly in the process as a number of the mushroom caps were broken off. To his credit the creator had actually attempted to fix them with little greenstuff balls and once painted you can’t really tell the difference. The wildest thing, however, was the moss that you see on there was actually part of the model. Not the color of course, but he had attempted to actually cast a fuzzy moss. I wish I had taken pictures before painting it now, but it was stringy and sort of soft, as a very thin resin would be. As soon as you put paint to it it sort of wadded up and you lost that definition though.
Like I said, ambitious. And I certainly don’t regret the purchase, they work beautifully. Plus his own lore mentions poisonous spore clouds surrounding them them, so there’s my Blazing Body analogue!
Before writing this I decided to look it up again and found that he did actually run a second wave through some site called gamefound, which appears to be a kickstarter for gaming specifically. It didn’t succeed, but I don’t blame him for trying a different service. The biggest players (kickstarter, paypal, etc) are always the greediest. He did bring in some heavy hitters for help though (Garden Of Hecate and Boris Wołoszyn) as well as using siocast instead of resin, so I imagine things would have turned out better had it succeeded.
T. Furius Sinister, formerly Corrector of the North
by @Antenor
“Listen, Furius. We’re both soldiers, so let’s drop formalities and have straight talk now that the politicos have retired. I’m happy about your success, but you know how these things go. I commend you for your excellent service as Corrector of the North, reward you quite handsomely, and give you some fancy title. Then I send you off to a new command at the other end of the empire. You win great victories, repel the barbarian hordes from our lands, maybe even launch a punitive expedition into their own territory. Your legions get stuffed with loot and extra pay, and before you know it, they start thinking, “You know what? Our general would make a great emperor!” And one fine morning, they pull you out of bed and raise you on a shield before you’re even fully awake.
“At that point, it doesn’t even matter whether you want it or not, because you know that if you refuse, your head will end up on the nearest spear. So you accept their acclamation. You promise to shower them with gold once you’ve won the throne and proceed to march on the capital at the first opportunity, because that’s what is expected of you. I, of course, set out with my own army to meet you halfway. In the unlikely event that neither of us has been murdered by our own bodyguards by then, we’ll have to battle it out, and that’s pretty much the toss of a coin. You lose: you’re dead. You win: congratulations, you now have fundamentally the same job as before plus an idiotic load of parchmentwork, everyone asking you for money all the time, and half the people in your own house plotting to kill you. And in ten years, tops, you’ll be sitting right here where I’m sitting now with another young, talented, and popular general in front of you. So let’s handle things differently and both be better off for it, shall we?
“As of this moment, you are relieved of all military duties. Instead, you will travel as my personal envoy to strengthen our ties with our recently discovered kin across the great sea. Be polite and make yourself useful, and I’m sure there’ll be a splendid career in store for you there, with neither of us having to worry about or, indeed, ever see the other again. Deal?”
It is with great excitement that I am able to (re)introduce T. Furious Sinister, a coveted Antenor Original, charged with his envoyship during our fortuitous CDOffline only last month. A most gracious host indeed!
Having successfully completed his journey across the great sea he has now united with the forces of Ginëladan. May our empires blaze like the sun!
