[TOW]Dreadquake Mortar base size
Hi guys,
Just wondering what the basesize of a Dreadquake Mortar should be.
Rules say “Base Size: N/A” but the Dreadquake Mortar is quite a bit bigger than the old Earthshaker Cannon that I want to use.
I don’t have the newer Forgeworld model.
Ofcourse it’s even more confusing that I has the Steam Carriage upgrade, so I would have to know the size of the Dreadquake Mortar model, without the train cart?
Who can help me out? What size have others used?
I took some measurements back in 2018, which I posted to my old blog: https://www.chaos-dwarfs.com/forum/showthread.php?tid=5804&pid=285700#pid285700
I came up with 2” x 6.75”
That’s huge!
75 x 50 mm would fit the model so well, might just have to stick with that. Or go with a 100 x 50 mm base to get a bit closer to the intented model.
Just found this whole discussion about this:
So I guess 50 x 100 or 60 x 100 mm is the consensus.
