[TOW] House Rules - Chaos Dwarf Armies of Infamy for The Old World
This is being written primarily as an allies list to buff out the differences between the 6th edition list and the TOW list, so it doesn’t include most of the units that are already available. Maybe I’ll fill it out to just be an update of the 6th edition list.
Early draft, not complete or anything yet.
Chaos Dwarfs Army of Infamy
Plains of Zharr Force Composition List
Characters
Up to 50% of your army’s points may be spent on:
Daemonsmith Sorcerers, Infernal Seneschals and Hobgoblin Khans
Core
At least 25% of your army’s points value must be spent on:
Dwarf Warriors (see Dwarfen Mountain Holds army list)
Dwarf Thunderers (see Dwarfen Mountain Holds army list)
Hobgoblin Cutthroats
Special
Orc Mobs (see Orc & Goblin Tribes army list)
Goblin Mobs (see Orc & Goblin Tribes army list)
Bull Centaurs
Rare
N/A
Notes:
The Irondrake weapons would be much better as a blunderbuss than the simple handgun that Thunderers have, but the buffed-up stats of the dwarfs that carry them make things a lot messier. There’s room to just create a new unit, just as would be needed for cavalry-sized Bull Centaurs.
Do they let slaves anywhere near the temple(s) for anything other than sacrifice and maybe cleaning? I’ve always imagined that it’s mostly Sorcerers/Sorcerer-Prophets and Bull Centaur guards, with backup from Chaos Dwarf Warriors.
Hmm, yeah, I was just trying to come up with a different name. Maybe just Plains Defence Force or Slave Expedition Force would be better.
Fair enough!! I went with something much wordier, which suits my Chaos Dwarf’s sense of self-importance, inflated egos, and outlandish titles.
Kind of fits with their over-compensating hats :wink:
Next revision
Characters
Core
Dwarf Warriors (see Dwarfen Mountain Holds army list, may take Hailshot blunderbusses for +5 points per model)
Special
Bull Centaurs
Rare
N/A
Since this is intended to be taken as allies, that means a 2400pt army can only take up to 600pts, and only 300 of that can be Special, so BCs have to be special to be feasible. That puts them as having to be less than 27pts each, which is less than Chaos Knights. For a 2K army, they need to be less than 23pts each for a unit of 10.
M.WS.BS..S..T..W..I..A.Ld.Pts
8..4..3..4..4..1..3..1..9..24
8..4..3..4..4..1..3..2..9..+6
Troop Type: Heavy Cavalry
Base Size: 30x60mm
Unit Size: 4+
Equipment: Heavy armour, barding
Options:
The entire unit may take a shield…+1point per model.
The entire unit may take great weapons…+1point per model.
A unit may:
May upgrade one model to a champion…+6 points per unit.
May upgrade one model to a standard bearer…+6 points per unit.
May upgrade one model to a musician…+6 points per unit.
Special Rules: Close Order, Swiftstride, First Charge, Stomp(1)
Pruned it down to the bare bones and put in full unit entries for the CD warriors and BCs.
This force may be taken as Allies by a Chaos Dwarf Grand Army. Magic items are available from the Chaos Dwarfs Legacy Army list.
Characters
Core
Special
Bull Centaurs
Rare
N/A
Units
               M WS BS  S  T  W  I  A Ld Pts
Warrior        3  4  3  3  4  1  2  1  9  8
Champion       3  4  3  3  4  1  2  2  9 +5
 Troop Type:  Heavy infantry
 Base Size:   25x25mm
 Unit Size:   5+
 Equipment:   Hand weapons and heavy armour.
Options:
The entire unit may take a shield.................+1 point per model.
The entire unit may take great weapons............+1 point per model.
The entire unit may take hailshot blunderbusses...+5 point per model.
A unit may:
May upgrade one model to a champion..........+5 points per unit.
May upgrade one model to a standard bearer...+5 points per unit.
May upgrade one model to a musician..........+5 points per unit.
0-1 unit may:
Have the Drilled special rule................+1 point per model.
Have a magic standard worth up to.....................25 points.
A champion may purchase magic items worth up to.......25 points.
Special Rules:  Close Order, Resolute, Shieldwall
Bull Centaurs
Bull Centaurs  8  4  3  4  4  1  3  1  9  24
Champion       8  4  3  4  4  1  3  2  9  +6
 Base Size:   30x60mm
 Unit Size:   4+
 Equipment:   Hand weapons, heavy armour, and barding
Options:
The entire unit may take a shield............+1 point per model.
The entire unit may take great weapons.......+1 point per model.
A unit may:
May upgrade one model to a champion..........+6 points per unit.
May upgrade one model to a standard bearer...+6 points per unit.
May upgrade one model to a musician..........+6 points per unit.
0-1 unit may:
Made it look all nice. A little updated compared to the one I put on the discord a few days ago.
EDIT: Higher definition images.
So here is my take on an actual Legion of Azgorh as an Army of Infamy.
I followed the usual Army of Infamy style rules (33% core, no mercs) but chose to keep the Warriors of Chaos as allies because LoA was introduced as being a big part of the Chaos forces in Tamurkhan. You can see how it is largely the same.
Compared to the Grand Army list:
I removed things that weren’t in the LoA army - Black Orcs, bolt throwers, the Lord-level non-magic character.
Note that Sneaky Gits were effectively a Cutthroat option in LoA instead of a separate unit choice, so I included them.
Removed restrictions on war machines or loosened them a lot.
Removed restrictions on Wolfriders.
Added Chaos Giant.
Added K’daai Destroyer and BC Executioner.
The K’daai Destroyer is pretty close to the LoA 8th edition rules, just a few updates to match the Fireborn.
The Bull Centaur Executioner is based on Shar’tor. The rules are based on the Taur’ruk and then beefed up to Shaggoth/Minotaur Lord levels.
I was tempted to add a bit to the Chaos Giant to make it more like the Siege Giant, but those rules aren’t all that useful in most games, so I just left it.
Great work. Hashut is pleased.
Because I absolutely cannot help myself, here is a full on TOW army list based on the 6th edition Ravening Hordes army list. I gave it the assonant name of Acquisition Expedition, because that’s largely what the army was described as doing at the time.
I’m also working on doing all of the 6th edition Storm of Chaos lists too. Got the 'Ardboyz almost done and a Cult of Slaanesh in process. I can’t vouch for how balanced any of these are, I’m just translating everything over as closely as I can.
Here are the full Storm of Chaos army lists:
I’m already more than half way through a follow-up, which includes DoW and Kislev, as well as some of the CD stuff above.
A third list is being planned, full of odds and sods like units missing from existing armies, and rarer army lists like Kemmler’s Army of the Cairns. I’d like to eventually cover every alternative army list from 6th edition onwards. There are probably a few White Dwarf lists that I don’t know about.
And now the next volume, if scribd lets it work. Seems to be hiding it for some reason.
https://www.scribd.com/document/735179727/The-Old-World-Chronicles-2276-v0-05
Alternative link
Army lists for the following:
Dogs of War
Dwarf Guild Expedition
Chaos Dwarf Acquisition Force
Hell Pit of Clan Moulder
Gnoblar Horde
Dark Elves City Garrison
Army of Kislev
Southlands Cohort
Army of the Cairns
The one after this is mostly based on Lustria.
Where did you get the formatting from for this? I want to expand on the ideas you’ve laid out
It’s just a Word doc with tables aligned with the background image.
Could you make a Google Drive link for The Preceding Storm PDF please, like you have for the one below, for Chronicles 2276, i dont have a Scribed account so cannot download it. Thank you.
This should work.
Hi Again, Thank you for doing that! I really love these! May i ask you for the blank page, blank side scroll and blank bottom title banner you used to make these too please? Id like to make my own House Rules Army List now and would love it to look the part like your do! Thank You.
Break links
