I made grids for all common square bases for Warhammer Fantasy and The Old World. Although it is most fun and thematic to place templates over the actual models, sometimes it can be a little hard to determine who is actually hit, especially after scattering. You can print out these pages (make sure to print at true size!) and do it on these, if you like.
As an added bonus, you can channel your inner German for TOW: If you are like me, you are neither going to rebase your models nor are you going to use adapter-trays. GW said it’s fine and won’t make much of a difference, but there is this nagging sensation that a template might hit less models if they were on the “correct” bases. Voila - just use the appropriate printout! Best of both worlds.
Square Grids.pdf (1.9 MB)
Includes grids for
- 20x20
- 25x25
- 30x30
- 40x40
- 50x50
- 25x50
- 30x60
- 40x60
- 50x75
- 50x100
Quick thinkers will realise that you technically only need the three root grids for 20, 25 and 30, but I think it’s cleaner this way. With access to a colour printer, one could even include multiple grids on one sheet of paper.
