tirli_pinpon:
Hello guys !
First, thank you so much for your comments and encouragements. I’m very glade you like my original theme.
And thank you for the slaves, I will sacrifice them in the name of Hashut-da Vinci ( a great CD painter
How do you paint the verdigris, paint it on first and brush over it with metal or paint it on in the end?
I paint it on the end. First a dry brush of Tin bitz, asecond dry-brush of tin bitz and boltgun. The a wash of catachan green and then I paint a mix of catchan + jade green + white ( 40-40-20 % ). I’ve got a step by step but it’s in french for the moment
How did you do the skin and beards?
Note that the skin is done the same way for the hobbos and the dwarves ( or dwarve ? )
First I undercoat in black.
The skin is made with a base of liche purple and dwarf flesh ( about 50-50 ) , then highlighted with a mix of liche purple + dwarf flesh + white ( 20-40-40 ) and a the final one with just dwarf flesh + white.
The beards are easy, first kommando khaki, then bleached bone, then bleached bone + white.
How do you make your green lava bases?
Very simple, first I put a little ball of miliput ( a sculpting paste, you also can use greenstuff of course ) on the base. when it’s dry I put some white glue on, let it dry, and paint it with catachan green, then with catachan green and camo green, then camo alone, and to finish, a wash of catachan green.
sur Warmania y’a une section NdC, n’hésite pas à y faire un sautWarmania has a section NdC in it, do not hesitate to make a jump there
Je passerai y faire un tour
I will have a look
I used the online translator. Is it correct? What is “je fais le même truc pour”.
I think you can translate it with :
“I do the same stuff for”
The rest is good
This last days I’ve worked on the hobbos, but also on marker for the units “shaked”… pictures tonight
