What´s about these wings (the problem is that I didn´t know the exact size)?!
Zanko
Nine dollars? What is that in Euro :cheers But i like these wings, they look a little bit more "evil" than the standard gw ones...i´ve to check some more wings, if the sizes is ok for my taurus.
Nevertheless: more progress on Mister Taurus!
I finished most of the green stuff work and started to bring on some horns on the back and the neck, although i´m not very satisfied with how the horns on the neck turned out.
On the femoral (i learn a new word every day ;) ) you can see some tests of self made scales...don´t know if i wanna do more of them...x.x
I gave him a first couple of washes for the fur, the skin and the horns. And i received the hooves for him from a friend. But i´m not sure how to fix them to the model...don´t want to cut of his feet...hmm. Any suggestions?
thanks for the scale picture it looks just the right size big enough to be intimedating but no so big he will make the rider look small.
with the feet I would cut and pin it souldnt take to long as the feet are plastic and it will be very strong. I cant see a way to put the new feet on without cuting the old ones of without spending hours holowing them out.
I used the same hooves for my Lammasu, I simply removed the origninal feet and pinned the hooves in place and covered the gap with GS. Thou make sure you use a long pin so it goes from the lower leg - throu the hoof - and down the base for better stability to the model.
