That looks pretty nifty. Is the scalemail done in red sculpting putty? I've never heard of or seen anything like it before.
Good execution of that concept!
Admiral
I dont know the name of material so I'll put the picture of it,I know kids use it in school,its cheap,nice for working and it gets hard only after cooking it so you can work on it for days,and after putting it in boiling water it is almost same as plastic. The hole thing is made of this.
Now that you mentions it, Yodrin. Is that a Chariot (50x100mm) base?
In that case, a Screaming Bell (60x100mm) base will allow it to rank up perfectly with infantry on 20mm bases. Could be worth a purchase of bases from GW for all those cool dioramas, unit fillers and warmachines.
No,its a unit filler so dident want to go too far,it is replacing 8 miniatures so the base is 8cm wideand 4cm deep,he is around 10 cm and a base itself is made of klirit,my friend has a workshop and he is cutting it with laser so we are able to have whatever base size we imagine.
Magma demon(cannon) done converting and WIP of Dhrammin the Forgotten summoning his taurus(putting the limited edition sorcerer behind on the edge of cobble stone floor).
Really nice work. I especially like the Troll vomit conversion on the Balrog. If you add a few rivets to the shackles of the Daemon it should have a perfect level of detail.
Some progress on infernals, and it finally comes to make my death shireker demons, fire demons burning down victims thrown into pools of lava and shooting out their souls, can;t wait to start it
