One thing that I don’t like about Chaos Dwarfs, is the “blocked” barrels of their blunderbusses. I have noticed that people paint a big black cirlce or star-esque shape on the end of the blunderbuss, but that wasn’t enough.
I have drilled out a few of the blunderbusses, and I think they look great. But I want to know what other Chaos Dwarf Generals think? Is this a good or bad idea.
Yup, it looks good and adds that extra bit of relief. Even painting a flat end with complex shading still looks pretty lame. Its always better to get the depth in, IMHO.
I will be posting a tutorial on how I did it. It is fairly easy, but a little time consuming. I will make sure to include as many photos of the process as I can.
@pyrostick, a small part of me feels the same. It was hard to start cutting up the original models. But now with the positive response that I have just received I feel good about it.
I think it looks good as well but as usual im against destroying the original models.
Pyro Stick
There is a difference between destroying and improving! ;)
Think of it as classic cars, people might put a new radio in them if they are renovating it, or new tyres on so they are up to regualtions (e.g. standards were loads lower then!)
I am intending to drill mine… When I have time… After I gather the needed diamond beads… And build them… and get all the replacements from forgeworld… Sighs
Did you use a Dremmel to get the material out of there? Wonder if its worth repainting all my Blunders to get the holes drilled out - they certainly do look much better like that.
Always wanted to do this but never really known how. Maybe post in here the basics of how you did it? Also, the reason they were flat ended is becaue of casting tchnology and techniques back then - it wouldn’t have worked, put simply.
