[Archive] Frost's Legion *kit-bashed skull cracker 3/13/12*
Singleton Mosby:
I'm loving this conversion!
Where is the roller-bit on the front from?
Discoking
40K Ork roller
frostbit3:
Looks nice, frostbit. I actually considered using the deff roller too, but I was afraid it would be too big. Seems like it works fine.
Did you use liquid green-stuff on the wheels? It seems to be green. How did that work out for you?
JMR
Thanks JMR.  The terrible unit is now in my army thanks to you!  The piece of plastic under the model in the picture is actually the 60x100 base.  The deff rolla overhangs a bit on each side, but that doesnt sway me. With the platform of the doomwheel removed it fits comfortably 100 deep.  You will need to modify the the arms to the roller, or the bit where the skaven cannons attach if you don't have something to use as a spacer.  The lascannons worked perfectly.
The liquid greed stuff was fast, and had a minor impact. Two coats would be better, but I am lazy. I am glad I did the one coat though. Should make it look slightly more like torn up metal.
