I am about to start some mounted characters for my CD army. The beasts will have the same size like the current Taurus and Lammasu - so it would be obvious using the metal taurus wings for both.
But there is two problems doing that:
1) Only have one spare set
2) And biggest problem is, that the wing joint (wings to beast body) is too big for my Lammasu idea - so I will need another pair of wings - with a smaller joint.
And 3) I want - as always - varity
So I’m looking for a wing substitute - aprox same size as the current Taurus’ - which mean 7-9cm long - but with a very small/smaller wing joint. The wing have to be of the ‘bat-looking’ type - no feathers please
First, that comes to mind is Winged Nightmare wings - anyone who could give me the measures for these?
But please, give me your other recommendations - and if you can, please give excat measures. And there will be slaves for close up pictures with measurement references (like this one:D)
This picture shows the Taurus wing and my main problem - and also giving you the excat measure for reference about what size I’m looking for.
Plastic dragon wings? Can even be bitz ordered from GW. Or the LotR equivalent which should also be available.
snowblizz
From the elven dragon? - I can tell you - they a way to big - and so are the old plastic wings (and they are not stretch out) - it's just for a bull sized beast - not anything as big as a dragon.
No it has to be from those middle sized Monsters - I think.
And just for the record, you can also bitz order Nightmare wings, zombie dragon wings and a loy more.
Anyway, do you have the measures for plastic dragon wing?
snowblizz
clam
I was thinking about the "old" plastic dragon wings, the new HE ones aren't available AFAIK. Unfortunately I do not have the measures. I'm not in contact with my wings ATM.
And I think your are thinking about this backwards. The wings aren't too big, the bull is too small :)
I don't think the dragon wings are that large... oh well.
Dark Pegasus wings perhaps, should be around 5-7 cm
Nightmare wings could fit as well, the monster is about the size of the Taurus I'd imagine.
I would think that the old manticore from GW with a undead necromancer is just about right. Havnt got a picture, but its in the rulebooks from 5 th ed with the lizard vs brets.
This is it with a little greenstuff (see below) allthough theres no clean wing shot, if you beg my pardon.
Kroppen er stort set samme størrelse som en lammasu, ved jeg som indehaver af begge modeller og både lord og sorcerer skræver nok lige akkurat nok til at kunne sidde på den.
I would think that the old manticore from GW with a undead necromancer is just about right. Havnt got a picture, but its in the rulebooks from 5 th ed with the lizard vs brets. This is it with a little greenstuff (see below) allthough theres no clean wing shot, if you beg my pardon. Kroppen er stort set samme størrelse som en lammasu, ved jeg som indehaver af begge modeller og både lord og sorcerer skræver nok lige akkurat nok til at kunne sidde på den.
Pyhat aka Rune
Pyhat
Heeey, no Danish! Unless it is Danish pastries at any rate... For the Manticore wing size check: http://www.solegends.com/citcat94/cat1994053-03.htm
However getting hold of them...
EDIT: OOoooooooooooooh! Now THAT'S a Taurus. Going in search of more pictures as we speak.
Thx, guys - but isn’t there really noone who kan give me measures for current Nightmare wings? - No, VC players here? I don’t belive that.
@Pyhat
Welcome, Rune nice to see another Dane join ranks - but let’s stick to the english here (Are you a Powerfister - too?). And thanks for the tip about Manticore - but I think it will be hard finding just the wings for that old beast - but I’ll keep an eye out.
@Ishkur
Balrog wings are way to big for my ‘Lammasu’ - i yil have to cut an additional 3-5cm off - but I might look into this for my Taurus ‘conversion’ - which will be slightly bigger. So the original Balrog wing is just about 13 cm in total?
@Snowblizz
thanks for guiding me to the 1:1 Manticore picture (slaves goes to you)Â Â - and please find another link for current Nightmare and Zombie dragon as well, please
How about the bloodthirster wings ? - they are of similar size in terms of length although they have a greater area - I can measure mine of you want me to
Sophia is a great sculptor indeed! I have metal wings I bought in a little shop in Praag and they look very similar, hence I thought they might have been the same…
