one or better two numbers smaller would fit much better!
Zanko
numbers smaller? :~
which? height or width? its the same height as a tjub pin, so i'm guessing width? i quite like the broadness of it to be honest. :~ i'm in a muddle now.
maybe i should do a rank of them?? see what they look like ranked up? Perhaps I could clip the bottom of the pin off to make it shorter but keep the broadness??
Just eye balling the picture relative to the base... its about 12-15mm at the largest diameter and about 20mm from brim to spike tip.
aka_mythos
oh yeah, *doink* - didn't think of that.
I make mine (after a 'technical edit' involving a hacksaw and removing 8mm) about 18m wide and *now* 6mm tall.
I have a funny feeling i’ll be getting a few more of these done tonight. Then the green stuff can come out to play
I do love doing the dread beards.
Also I got my Immortals helmets done tonight, they are pretty cool, and even thought of a way of covering up the moulding lines and the faults that come from my method of casting - they might look a bit ‘beefeeter-eque’
Question… how are you finding them to rank up though? I am also trying to make mine with GWs… though am concerned on how they will rank up nicely… or at all in some cases…
Question.. how are you finding them to rank up though? I am also trying to make mine with GWs.. though am concerned on how they will rank up nicely.. or at all in some cases..
grisnik
Basing:- trail and error, I find that the turny bases actually make it easier to find positions that they work in. Great weapons managed to get five next to each other, and they look quite good. - need to be caseful with the green stuff dreads though to make sure I don't make a mistake.
Left:- Immortal with my odd heads, Right:- Blunderbuss - to short?? - its telescopic so i can make it about 1cm longer if needs be. i'm not sure how long to make it.
I think they looks pretty nice. alot better with the new beards, tusks look good. the only thing I would try to do is sculpt another line in between each of the beard curls. I always felt that the beards looked nicer the tighter the curls are. although, I have never attempted to sculpt bighat style curly beards before.
Da Crusha
i would have to agree about the beards, but apart from that they are looking pretty nice :hat off
I think its more a comment on the texture of the beards. Rather than having lines that go completely across each lock of beard, try making them only go part way across alternating which side of the lock of beard they start from. That seem to be standard look. The way you have them, while they look good, maybe too good in a sense.
