Time of Madness:
It really makes Full commands vital to main units. However charging won’t always be the best option for some units.
Time of Madness
Time of Madness:
Time of Madness
Yep, I think the random parts of it really are just to add a bit of flavour and chance; I doubt it will impair good generals, although it does nerf units like Ghouls who have no command.
Rather than just say ‘check the warseer sticky’ for the latest rumours… which I just did… I’ve put the link in my sig.
Some new things today; allied % are not in, rules for using allied forces are. It will be interesting to see if the CD are in the alliances chart. I doubt we will be, but you never know.
I may have added some other things today I can’t remember.
Bolg:
@Grim, thanx for the green updates, so i dont have to reed everything all the time (:
LumpinCroop:
It’s difficult for me to be excited about the new edition when I know in my heart our army will get ignored.
Time of Madness:
In another week and a half we should have a lot of the answers as most stores/managers should be receiving store copies.
Any idea how many options there will be for buying the new book? Sounds like they have some different promo’s going on.
Time of Madness
For you guys seriously following this stuff, I have done a fairly big update of the 8th ed rumours sticky (link in sig).
zobo1942:
Does anyone know if the new 8th edition rulebook will contain rules for playing small scale games (like ‘Warhammer Skirmish’, etc…)? As much as I like the look of large units, etc… there is no way that I have the time or the room in my budget to be able to afford to create an army that large.
Most of the things I have heard have been about creating bigger games, not smaller ones.
Just download the Mordheim rules from the GW website. It’s the rules that Skirmish were based on, but it has more stuff - even for one-off games, like different weapon rules and special critical hit tables.
The Border Patrol rules should be lurking around too, it’s like a mini game of Warhammer.
Plus there is the Warbands rules, but I don’t know how easy they are to find. They used to be freely available on some of the GW sites but not all, and they weren’t publicised much.
I wouldn’t normally bump this simply to say I’ve updated the rumours sticky, but the last update I did was massive. So people may find some of it interesting.
See link below.
25% max characters and 25% lord 25% heroUh? 25% Lord and 25% Hero? So 50% total?
That seems more reasonable. Does anyone know if that’s going to be different for Bretonnians, btw? They’ve always been allowed to take more characters as standard - maybe their compulsory BSB won’t count for the limit or something?
Time of Madness:
Each army is going to have it’s own differences. I’d assume high elves wouldn’t have to take as much core for example.
Each list is going to be given a quick list update at the time of the release (think ravening hordes).
Time of Madness
I highly, highly doubt we’ll see Ravening Hordes 2.0 for 8th Edition - Ravening Hordes completely overhauled the current Armies books. There’s no way they’d release Armies books so close to them being made obsolete. Beastmen only came out a few months ago and contains elements that make more sense in 8th Edition (look at the way Ungor Raiders are set up in the battle scenes, for example) so that one’s here to stay at least. What you’ll see is PDF FAQ documents of the kind that came out for 4th Edition 40K to make the old books playable.
The bizarre fantasy of “everything starting from scratch” and PDF army lists is as silly as ever.
Time of Madness:
Maybe ravening hordes was a bad example. You will see a document that contains most armies with the changes (errata’s) for 8th edition.
Time of Madness
Yeah, I think that’s a given - otherwise nothing’s going to be playable. I would imagine they might take the opportunity to do a normal FAQ for those that are still outstanding in the same document.
People have seen printed in GW rulebooks 25% max characters and 25% lord 25% hero. I think many GW stores will be basing their demonstrations on 25% lord 25% hero. Make of that what you will.
Allied Forces
Allied forces will not get a % allocation. However, rules for using allied forced (i.e. an updated allied forces chart) are in the rulebook.
Allies are now split into 3 groups:
Forces of Order: High Elves, Wood Elves, Lizardmen, Empire, Dwarfs and Brettonia
Forces of Destruction: Chaos of any kind, Skaven, Greenskins, Dark Elves (edit. Vampire Counts may go here).
Neutral: Ogres and Tomb Kings
The allies rules are intended to be used by more than 2 players. You are not supposed to use more than one armybook in your army.
Allies are allowed to use the other army General�?Ts leadership, but cause panic in units of the other army if they are forced to flee. If an allied unit is forced to flee through another ally from a different group, the stationary unit counts as dangerous terrain. I.e. High Elves flee through Warriors of Chaos
You may measure distances whenever you want.
Charging.
Rumoured to be:
Infantry M1-M6 = Basic Movement value + 2D6
Fast Attack M7+ (Cavalry and fliers) = Basic Movement value + 3D6 use 2 highest)
+1CR for charging. -Avian (more likely)
Fliers
Move 10 " and march 20 ". They ignore terrain whilst moving. While fleeing or pursuing, they use their ground movement. (note: the ground movement part may not be entirely correct)
Marching.
Movement distance as normal. When there's an enemy within 8", the unit has to pass a leadership test to march. Not sure how this applies to Dwarfs.
Reforming
Units may reform once, but may neither move nor shoot the same turn. If the unit has a musician, it may move afterwards, or shoot. (Note: I'm pretty sure I'm missing some details on that one.)
Generating Power and Dispel Dice
Power dice aren�?Tt generated by the number of spellcasters. The amount of dice is decided by 2D6. The active player gets the total as power dice and the other player the highest throw as dispel dice (throw 3+5, = 8 PD and 5 DD). (confirmed)
Channeling (confirmed that it exists)
Each wizard may roll a D6 and generate an additional power dice on a roll of 6.
Each enemy wizard may roll a D6 and generate an additional dispel dice on a roll of 6.
You may not channel while fleeing, off the board or when you suffer from stupidity..
Maximum Power and Dispel Dice
The maximum number of power or dispel dice you may have at any time is 12. This includes any power/dispel dice generated by special rules, spells and/or magic items.
Casting Spells
To cast a spell, roll 1 to 6 Power dice and add your caster's power level. EG: A Slann casts fireball and uses 2D6. He rolls a 3 and a 4 - score of 7. He than adds his Power Level of 4, which results in a total roll of 11.
Miscasting
Here is where I think we need a lot more information.
It is rumoured that miscasts are entirely gone, but are replaced by a combined irresistible force/ miscast table effectively:
When you roll a double 6 the spell is cast with irresistible force, but the Caster has to roll on the "lost control" chart, which is devastating, and far more worse than the current miscast table.
Lost Control Chart
Roll of 1: This has been confirmed as being even worse than number 4�?� Which (pure speculation) may involve every model in the unit taking a hit, this was something I actually heard a while back, but it could be worse than this.
Roll of 4: The wizard is sucked into the warp and the large template is centred over him. S10 hits for something (could be the centre model, meaning S5 for the rest?).
Bound spells
Bound spells are cast like normal spells now, but instead of your caster's power level, you add the level of the magic item. (Not 100 % sure on this one)
Spells are now categorized. There are: Missiles, Curses, Buffs, Direct Damage and Power Whirl spells.
Missiles: Require Line of Sight and may not be cast into close combat.
Curses: Modify enemy stats and/or equipment
Buffs: Support your own troops
Direct damage: Spells that use templates or apply to the whole target unit.
Power whirls: Apply to all of the battlefield or move across the table.!?
Each lore has an additional effect. For example:
Lore of Shadows: After the wizard successfully casts a spell, he may switch places with another friendly character of the same unit type.
Lore of Death: For each wound caused by lore of death spells, roll a D6. On a roll of 5+ you are granted an additional power dice.
Lore of Fire: If the enemy suffered a from a fire lore spell earlier this magic phase, the caster is granted a Bonus of +3 when casting a fire spell upon the same target.
Lore of Metal: Direct damage spells from the lore of metal have no strength value. Instead the unmodified armour save of the target is the required roll to wound. This causes flaming attacks and ignores armour saves
True Line of sight
Units draw true line of sight. You are considered in cover when shot at through another unit, granting a -1 or -2 penalty on to hit rolls. Note that someone else has said this is more likely as well.
Supportive Attacks
Infantry models in the second rank can fight, with a maximum of 1A per model. - Avian/Harry. Great weapons can only be used in one rank. �?" Godless.
This is only for models fighting to the front. Units charged in the flank or rear only fight in 1 rank, but being charged in the flank or rear will not stop units fighting in multiple ranks to the front.
Most special rules apply as normal. however... Whatever combination of weapons/ special rules/ spells/ whatever, infantry can only ever attack with 1 attack per model in the second and subsequent ranks
Rank bonuses
Unchanged. Up to 3.
One Save.
A model can always take an armour save. They can then take either a ward save or a regeneration save.
Crush them!
Monstrous Cavalry and Monstrous Infantry are granted 1 bonus attack with the "always strikes last" special rule, at base strength
Destroy them!
Larger Creatures and Monsters do D6 attacks instead of 1 attack for crush them
Change to Wound table
All the �?~N�?T are replaced with a 6�?� I�?Tm taking this one with a fair bit of salt.
Breath Weapons
Now apply in close combat, dealing 2D6 hits with the breath weapons strength. This is in initiative order. At the moment it looks like it will be in addition to regular attacks, not instead of.
Great weapons Always strike last (this overrides any army book rules). Can only be used in the first rank. - Godless
Always Strike First
ASL combined with ASF cancel each other out. Strike in initiative order.
However ASF + higher initiative than your enemy: Reroll to hit rolls. So even if Swordmasters and White Lions are striking in initiative order they may get re-rolls to hit!
Frenzy
You still get +1 attack on the charge (front rank only). You may suppress charging with a leadership test. If you fail, you have to attack the closest target.
Magic Resistance
This has been changed to improve an existing Ward Save, or to grant a Ward Save to magic.
Magic Resistance 1 = +1 Ward Save against Magic. For a unit without a ward save this is 6+
Magic Resistance 2 = +2 Ward Save against Magic. For a unit without a ward save this is 5+
Magic Resistance 3 = +3 Ward Save against Magic. For a unit without a ward save this is 4+
For things that already have a Ward Save, Flesh Hounds for instance, they have a 5+ Ward save already, and MR(3). This gives them a 5+ save against shooting/ combat, and a 2+ Ward Save against magic.
Regeneration
Regeneration will come in several types. The Slanns ability for example will grant him Regeneration (3+), while there is a mundane magic item that grants regeneration (6+).
Time of Madness:
Thanks for posting those, makes it easier when they are all in one spot.
Time of Madness
Cheers Wallacer. Saves me posting anything here. Fortunately you have copied the version after some of the quick edits I had to do. There is another one to add though:
Salvo FireIncidently I believe I have set myself a new record for pm received within 24hours, about 22.
A rumour I heard a while back was that units with bows (see above), could fire with more than just 2 ranks. What I am being told now is that regardless of the width of the unit, a unit with bows may shoot with an additional half a rank behind the 2nd. I.e. 12 models wide, 3 ranks (36 models). 12 front rank, 12 2nd rank, 6 3rd rank = 30 shots.
