In order to host parallel games in my apartment, and allow more players, I’m looking for the best way to have a modular table that can be folded to take no room. I’m going for 2,10m x 1,20m (30cm extra beyond playing surface). I have an extensible table which still takes surface when extensions are removed so I’ll go for the old big wood panel and 3 trestles to support it so that the second one is easy to conceal.
Which material, thickness would you suggest me ? I need to be able to move it alone, I’d rather avoid chipboard panel because it crumbles and you need a thick panel to have the rigidity. MDF, OSB, plywood, melamine, full wood ? which essence ? which thickness ?
For the trestle, I suppose I need treated wood (in case I keep it in my garage), smoothed surface, foldable. Max resistance isn’t going to be important I guess. What else should I check to choose trestles ?
I use three 4ft by 2ft (1200mm by 600mm) white plastic folding trestle tables with a heavy cloth over the top. You could add a fourth one for a 8’x4’ (1800x600) play space. They take a little space when folded up but no more than separate trestles and boards would. It also means that you’ve got some spare tables for whatever other things you need it for.
The specific ones I use are the Lifetime height-adjustable ones.
So from what I can tell it’s available periodically it was not available in the weeks prior to when I ordered it, too. There was at least one other store offering one, but I don’t have that information with me right now.
While less esthetically pleasing, it’s possibly the most versatile solution.
Instead of a technical solution of simply material and thickness, I have several well-thought ideas on your part guys, each valid, to be able to tidy this more easily.
