Picture time!
Here we have a re-do of my Taurukh Anointed. I used the new Chaos Knights for the lower half (higher detail than the old ones). And for the torso, I used 40K Ogryn armour. The shoulderpads are Stormcast, and the faceplate is from a Talos. I have since added a mace for the weapon, but am not sure where I will get shields that are big enough…
Next up is my Overlord.
This guy is quite the mix & match. I used a Hammerer for the lower half of the body, and widened it. The torso is one of the Fyrsylr (I can’t spell it) characters, and the hat is a Hammerer one but turned around and with horns pinned in.
The weapon is from a Slaanesh Daemon Prince, and the shoulderpads from Helllstriders. And that absolute UNIT of a shield is from a Chaos Knight champion.
Here is one of my Giants.
This was a lot less work than the other models. It’s a Slaanesh Daemon Prince, but with scale-mail sculpted around his hips, a beard, and his weapon replaced with a Dragon Ogre hand weapon. In his other hand will be a LotR Isengard Troll shield, but it won’t go on until after he is sprayed.
Some basic Infernal Warriors now.
This is again, a more simple conversion. Bodies are Hammerers (all my dwarves incorporate them somehow, to make the army more uniform), and the heads are Black Guard. Although I will be filling in the elvish on their foreheads.
Weapons are axes from the fyrslayer infantry, pinned of course for extra strength. And I won’t be adding shoulderpads, to give them a different silhouette to the rest of my infantry. Speaking of…
I re-did my Immortals.
Here you can see I, again, used the Hammerer as a base, but kept the Blood Bowl dwarf face-plate. The spear is from the Dark Elf spearmen, and that fantastic shield is from the new Chaos Warriors/Knights.
Interestingly his shoulderpads are the inside of Stormcast arms. Smoothed down with a file to give them a perfectly round look.
And that’s all for now! Stay turned for my Slaves, as they are nearing completion…and I made a small adjustment that makes them look far better.
