Hello!
as per the title, how tall is a forgeworld chaos dwarf mini from foot to head or foot to shoulder? 24mm? I am having a hard time scaling some 3D print files.
Hello!
Most helpful @Jasko !
About 22mm tall with the base subtracted?
Thanks all! I think I’m about right - I’ve gone slightly smaller because I hear the forge works dwarfs are a pain to rank up!
Looks good! And you’re not wrong there, the forge world ones are not the easiest ones to rank up, depending on the weapon. It works if you adhere to a very strict posing regiment, then they rank up in exactly one formation
I think @MichaelX went the same way with the LKM prints and went a little shorter.
Their physical models, back when they still sold these as models, were a tad slimmer too.
After printing and painting 30 of the bigger ones…
I indeed went smaller. To roughly 90 or 87%. It somewhat depends on each model.
The advantage of 3d printing. Don’t like the size… ok, change it.
I ended up doing 85%, probably wouldn’t want to go any smaller otherwise weapon handles etc start to get a bit thin
