so what I’m hearing is… magic
makes wizard-like noises No!
Been running the tool for a few more hours, adding some fixes to logic as it goes. At 2.6K posts.
this WILL take a while
1% done!
Ok, another “bug” found. Apparently MyBB allows identical thread names (
) and discourse doesn’t (
) so when the API returns that specific error i suffix the subject with (n) where n is a number starting at 1. I HOPE THERE ARENT MORE THEN 9 TOPICS WITH THE SAME NAME… I was too lazy to implement a single and double digit check
2.5% done
Fingers crossed there aren’t many duplicate named threads. Great going @MichaelX . Got flu at the moment and no energy to check up on the new uploads, so fingers crossed it all turns out fine.
Best of luck.
@denelian5 : Thanks for checking them out and reporting errors! Valuable help.
No worries, i can just delete a whole thread and redo it f weird stuff pops up. So relative pinpoint fixing should work fine
Guys,
i (temporarely?) enabled the setting to allow ALL CAPPS POSTS on discourse.
allow uppercase posts
is the setting
We can enable after migration if needed.
Today I saw a link that was matched wrong. Don’t know how it happened because others were correctly changed.
Maybe we can create a thread after all Is migrated that non staff members can post errors/markup mistakes that staff can fix.
Bad idea or not?
Also… wait until It’s all done or do it now?
Some things may get fixed in the process? Maybe wait until it’s done to go error hunting?
Only stuff that points to chaos-dwarfs.com and Xander.ca. something.
If a link points to discourse but it’s wrong, that’s a bug.
But yes, maybe wait a bit longer. Maybe until we are at 50% at least
I FEEL LIKE IT WILL BE DIFFICULT FOR INDIVIDUALS TO MAKE A DIFFERENCE OVER THE SHEER NUMBER OF POSTS. MAYBE IF WE RESTRICT IT TO MINIATURES SHOWCASE TYPE THREADS, THAT WILL BE THE BEST SOLUTION.
I didn’t really mean to do it as an active thing, more like “hey I found this while browsing but only you fancy staffers can edit those posts” thing
ah I see! Yes, I think in a few cases we might even see people seeking to restore the best blogs. it’s so great having them brought back to people’s minds, I’m sure we’ll see lots of exciting things.
I THINK i fixed the last bug. There was this rare case where posting failed and i just figured out why. Lets see of it keeps running now.
Also… in about an hour or 2 well be at the 10% mark.
I fucked up
i deleted all the processed, so now the tool thinks it has to start over.
I tried rebuild the table from discourse but it changes part of the message and that causes me to not be able to mach them.
Im considering starting over but doing it a bit differently.
I’m considering doing all the parsing first, then start to upload it after. And keep track of what i uploaded in my local DB so i don’t need to poll Discourse as much.
It will be faster in the end, but it SUCKS
Ah, too bad…
Do whatever you think is best!
Its already reset. And its about 3 times faster, on average. So instead of 22 days minimum we are now looking at 6.6 days minimum. Non stop that is. Still… much faster
Ouch! Too bad, but perhaps it will work out better from the ground up this time, as well as going faster? Best of luck, maestro! In Daemonsmithing’s arcane datalore we trust.
Alot more photos than I thought had survived… Such a treassure!
Yes, and more will hopefully be added once transfers are complete!
we’re at almost 100k posts now
