[TOW] Questions around the Steam Carriage movement and Mystical Pathway/Infernal Gateway
Hi again,
I am not sure how to use the Steam Carriage rule. First our war machines have M - , the Crew (CD) has M 3 and the Iron Daemons have M 5. Carriage Hauler is the rule of the Iron Daemons that states that up to two Steam Carriage war machines in the back arc of an Iron daemon and within 8 inch of it can be moved when the Iron daemon moves. Their movement also must finishes in the Daemon’s back arc and within 8 inch around it.
So how is this special movement handled:
  • The war machines use the crew’s movement (which means they are slower than the daemon (M3 vs M5))
  • Or their movement is substituted with the Daemon’s movement value which is 5 inch or 5 + D6 inch if the Iron Daemon uses its Lumbering Destruction rule
  • Or are the war machines just moved from one point in the Iron Daemons back arc to another point in the back arc that is now within 8 inch of the Daemons new position regardless of the Daemon’s movement value and the movement value of the crew.
Nevertheless of the possible answer I have a second thing that troubles me. The “Travel Mystical Pathway” conveyance spell of the Elementalism lore enables a unit that is not fleeing and that has not moved yet in the movement phase or is engaged in combat to be removed and placed within 12 inch of it previous position but not within 6 inch of any enemy.
Is this replacement a movement. I can’t find anything the declares that a remove and a replace action is a special kind of movement. The Dark Magic’s “Infernal Gateway” spell has this remove and replace action too but without the pathways’ addition that the unit cannot move again in the movement phase.
This could be important for the Hailshot Blunderbuss and of the Steam Carriage/Carriage Hauler rule. For the first it could mean that the CDs are teleported and still can use the Volley rule if “Travel Mystical Pathway” is no movement and for the trains it could dependent on the outcome of the question above mean, that if it is a movement, the train plus the war machines could be teleported :smiley: which would be tremendously funny.
Phew, another complex mess to deconstruct :sweat_smile:
In general, war machines move with their crew’s movement value, I think that part is pretty clear. But you’re absolutely right, with the Iron Daemon it gets a little … interesting.
There is an argument to be made that this is RAW. Rule only says “war machines with the ‘Steam Carriage’ upgrade […] can be moved when this model moves.” Doesn’t say anything about “using the Iron Daemons movement” or so. If we go for RAI, I would say this is NOT how to do it though. I mean the whole thing is already pretty abstract, right? How is towing supposed to work at an 8" distance? Doesn’t make any sense. But if we think about towing, then all carriages obviously move as far/fast as the engine pulling them, right?
I would say this can still be deducted from RAW and definitely fits with RAI. With the first version, it would be possible that a war machine starts it movement with 8" but cannot end it’s movement in 8". One could say “well, in that case you cannot make that move!”, but it really wouldn’t make much sense to me. It would also fit best to the whole part explaining what happens when an Iron Daemon charges or uses Lumbering Destruction.
I think this one is def out of the question. I don’t see real support from RAW and definitely not from RAI.
I would go for the second option! But def something which should be discussed with the opponent.
I would say: yes, using Travel Mystical Pathway is a form of movement. I think that’s supported by “The target friendly unit cannot move again during this Movement phase.” I would therefore say Blunderbusses cannot use Volley Fire after being teleported, but an Iron Daemon artillery train can be replaced as a whole. Agreed, it is funny! :slight_smile:
I will add both questions to the FAQ/Errata thread
I think that the movement rules in TOW are a mess! I like to handle it RAW so the war machines will move with M3 and if the Iron Daemon moves too far away so that the war machines cannot be placed within 8 inch they cannot profit from the possibility to move when the Iron Daemon moves. Even if they can be moved they have to follow each rule for normal movements. This way the rule is not that great but it is RAW.
What is also funny is that given the Daemon makes a charge move this move will happen in the charge sub phase and the Carriage Hauler rule says the war machines move when the Daemon moves. So this would be totally out of order which raises the question if a war machine could be dragged out of combat?Guessing and over interpreted…
For the conveyance spells I think those are no movements but they will enhance or restrict a units movement. So “Travel Mystical Pathway” teleports a unit (without performing a movement) but does not allow a unit to move in the remaining movement sub phase. Again guessing and interpreted
The Carriage Hauler should be a variation of the “Dragged Along” special rule replacing the 1 inch with the rear arc and 8 inch, the 10 strong unit with the Daemon, further restrict the movement to be finished in the rear arc and within 8 inch. Increase the movement equally to the D6 if Lumbering Destruction was used and handle the shooting exception.
Definitely playing it safe and as I said, there’s an argument to be made that this is how it’s supposed to be played. Still, I would discuss with the opponent before. I don’t think moving war machines at the Iron Daemon’s movement value is in any way game breaking, so should be fine. If in doubt, going back to M3 is always an option.
I’d say no. If at M3 or M5, the war machine still makes a move. So if it cannot move for any reason, e.g. because it is engaged in close combat, it also cannot move when the Iron Daemon moves. But I’ll add it to the FAQ :wink:
That would have massive consequences not only for Volley Fire or Ponderous weapons but for all Move or Shoot weapons, so all war machines, which would all be eligible to shoot after being transportet. I cannot see how this is RAI. But that means this is guaranteed to be addressed in a future FAQ.
Interesting. Yes it would have been prudent to make Carriage Hauler a version of Dragged Along.
Probably a bit of RAI but I’ve always played it as the carriage follows the ID. All of the other interpretations require some mental gymnastics to use. The main part that leads to that interpretation is:
These War Machines must finish their movement completely within this model’s rear arc and within 8" of its base.
And that Lumbering destruction means the ID might go all the way to 11 (and that “must finish” means that carriage is coming the whole way with it). It’s a train, any sensible person would make that interpretation. The rules are a mess though and it’s not clear at all especially because the rear arc is wide so you could spin from one side to the other and possibly travel further than max march distance too.
As for Travel Mystical Pathways, I’ve always interpreted it as the unit hasn’t moved for the sake of volley fire and Move or Shoot. Most people I’ve played with and tournaments I’ve attended have also had that interpretation. It’s a spell, unit disappears and reappears and that is what is written so it’s RAW. And yes, that does amazing things for blunderbusses. I’d totally argue that carriage hauler means the war machine follows the ID down the pathway too and would finish up wherever it was attached when it started.
I also take the interpretation that steed of shadows can work with marching columns to do a 36" flying march too. There’s a great combo there with drilled to launch units across the table and then shoot the turn after (with or without a reform as you can always use drilled again to get back into formation and 36" allows for a lot of wheeling).
This has been addressed in an FAQ:
Unless specifically stated otherwise (like Carriage Hauler, funnily enough!), changing a model’s position in any way constitutes a move.
Other than that I’m with you: The war machine should move exactly as much as the Iron Daemon does, no more, no less. That’s just how trains work (then again trains are usually connected and don’t have the real-world-equivalent of 8" between carriages :wink:). TMP for me works like the portals Dr. Strange uses or, well, the game Portal. It opens in front of the Iron Deamon and it moves through, so does any carriage.
Bringing up this old topic again since with more infantry now I am thinking of finally painting up my 2 Flame Cannons and trying out the Choochoo.
What are your guys experiences with playing the steam carriage so far? Has anyone of you got into an argument with your opponent about the correct rulings or could you all figure it out for everyone’s convenience before your games?
I think I would also argue that it’s best played RAI in moving the warmachine the same amount of inches the train moves. But what about TMP now? How do ypu guys play it?
Cheers
I don’t think it sees a lot of play overall, so not much experience.
Openly discussing it with the opponent before the game surely is the best way. From the three possible ways
a) War machine moves at it’s own movement, so up to 3
b) War machine moves the same distance as the Iron Daemon, so up to 5+D6 (for lumbering destruction)
c) War machine just needs to be somewhere within 8” of the rear arc (basically teleporting)
(b) seems the most sensible and RAI and I would always argue for this.
And it would work with TMP too, if every model ends its respective move within 12” of the starting position. RAW TMP counts as a move, and Carriage Hauler says to move war machines when the Iron Daemon moves in the movement phase. Now that I think about it - that should also be the case when the Iron Daemon charges. Interesting.
On paper you could do some neat tricks, especially if you go with with jasko option C. Which is RAW in my opinion.
You basically line them up, unleash the columns of fire and ….. misfire, reroll with the deamonsmith, shoot the columns, and ohhhh only like 4 hits because of “risk of being hit”
Yea I have an absolute miserable streak of rotten luck with template weapons lately. Don’t mind my grumblings.
:hatoff:
If you teleport your flame cannon with (c) I’d say it’s karma :wink:
We house rule it to be a variant of the dragged along rule with my proposed additions. Since I do not play tournaments I have no idea how this rule is handled. Maybe some community member encountered the situation and can report. This would help. We are also using the renegades rules. Maybe in the next version the hauling will be fixed. Since they for example also followed the suggestion to put the Great Taurus back on 5x7.5 cm base and turn it into a Monstrous Creature it could happen that they also catch up on this.
I only keep track of the tournament scene from the outside (Square Based do their stat-shows, for example) so I’m fairly certain I/we would know if someone used Carriage Hauler at a tournament - definitely if it were successful :wink:
We can ask Tom Carly, he’s one of the more prominent Chaos Dwarf tournament players. He’s in the Discord.
Thanks for your thoughts guys.
Yeah, I would greatly appreciate a better wording on this rule, be it within the renegade pack or the next bigger balancing patch from GW (which I rather doubt will tackle this one…)
I will now paint up my Flame Cannons and have a couple of games with them, arguing for option b and report back here if I have some experience.
Also consider: the iron deamon gets a free 90 degree turn due to Lumbering.
However, even the largest single model enjoys slightly more manoeuvrability than a tightly formed regiment of many models. Therefore, after moving, unless it charged, marched or fled, a Lumbering model may pivot about its centre to change its facing by up to 90°.
So presumably we can use this to change the facing of the cannon trailers as well? I had only considered this in light of the steam carronade, but my observation that this is an excellent move for flanking would also apply to an enflade fire from the flame cannon.
That’s a very good point!
Following the (b) scenario, you would have to make sure the war machine stays within the rear arc while still “only” moving at the movement of the Iron Daemon. Only with (c) you would then be able to position the war machine in the new rear arc after the 90° turn, effectively resulting in a potentially huge movement for the war machine.
I’d say it is within RAI to not be able to do that, given that the Iron Daemon with “attached” war machines wouldn’t be a “single model” anymore. As in, yes you can still make the lumber move but would limit yourself in a way that the war machine still stays in the rear arc and 8”.
Secondary question; if RAI is to form some kind of train, ie place one models base behind another’s , does this not block line of sight in the front arc of the trailers? The steam carronade only has a 90 degree front arc of fire, so if it is blocking line of sight for the trailers you can effectively only use the train to travel at a 45 degree angle to the line of battle, or you have to ‘tack’ back and forth across the enemy units.
Yeah thankfully this is the part where the train is just imagined :wink:
Rule says the war machines only have to be within 8” and in the rear arc, so they can be offset, the bases don’t have to be in a line.
